FaeMoon opened this issue on Apr 15, 2010 · 12 posts
FaeMoon posted Thu, 15 April 2010 at 9:58 AM
Thinking about doing some scenes outdoors and I need some good grass and stuff . I was wondering if anyone had used Fink's plants, meadows.. grass. I'm going for a darker fantasy type atmosphere.
edit to add I have bryce 6.3 but haven't played much with it. I also have PoserPro 2010. I see these weeds can be used in either program. I'm not sure which one I will use yet for these scenes. Any input is appreciated.
[http://www.renderosity.com/mod/bcs/index.php?ViewProduct=63465&Start=241&TopID=6389.
](http://www.renderosity.com/mod/bcs/index.php?ViewProduct=63465&Start=241&TopID=6389.)
mike1950 posted Thu, 15 April 2010 at 11:36 AM
I have some of the flowers and medows, I dont do much with rendering, but they were very nice. They do add up though if you are doing a large scene. (poly's and render time.)
seachnasaigh posted Thu, 15 April 2010 at 11:55 AM
I've used Flink's Instant Meadows. Works as advertised. They're fairly resource efficient, given how mesh plants eat up polygons. Flink arranged the grass blades so that a patch does not show obvious square edges, so you can just scatter a few patches here and there.
OSes: Win7Prox64, Win7Ultx64
FaeMoon posted Thu, 15 April 2010 at 11:58 AM
Oh, that's nice to know! It may be one of those things I have to let render overnight or while I'm at work. I'm eyeing the Terradome set at Renderosity... it looks nice and if these don't have square edges, maybe I could mix and match alot.
cspear posted Thu, 15 April 2010 at 12:27 PM
EDIT: my units are set to METRES in my prefs, so adjust the displacement value accordingly (in this example displacement is 2 inches).
PoserPro 11 - Units: Metres
Adobe CC 2017
cspear posted Thu, 15 April 2010 at 12:45 PM
Adobe CC 2017
FaeMoon posted Thu, 15 April 2010 at 12:46 PM
That's cool. I guess the shaders would transfer over to a rough landscape too?
FaeMoon posted Thu, 15 April 2010 at 12:47 PM
Oh, I see.. so it's more a lawn. :)
cspear posted Thu, 15 April 2010 at 12:58 PM
Yes, insofar as the grass stands straight up; but I've used it on irregular surfaces successfully.
Adobe CC 2017
FaeMoon posted Thu, 15 April 2010 at 1:11 PM
I'll keep that in mind. Could be very useful. Thanks, Cspear!
beos53 posted Sat, 17 April 2010 at 12:05 PM
cspear: what ".obj" did you you to put this "node-based shader" on. I cant seen to get it to work on anything I try
PoserPro 2014, Windows 7, AMD FX-6300 6 core, 8 GB ram, Nvidia
GeForce GTX 750 Ti
ypvs posted Fri, 23 April 2010 at 8:01 AM
Should work on Hi-res square prop or any other surface
Poser 11 , 180Gb in 8 Runtimes, PaintShop Pro 9
Intel Q9550 Quad Core cpu, 16Gb RAM, 250Gb + 250Gb +160Gb HD, GeForce GTX 1060
