Subject: Noob question M4
Trollzinho opened this issue on Apr 23, 2010 · 9 posts
Trollzinho posted Fri, 23 April 2010 at 1:02 AM
I've just started using M4 (instead of Apollo) and right away I noticed that there was no transformation to open/close the hand fingers when I selected the hands, like Apollo has. Am I missing something here? Did I forget to install something? I double checked everything, even tried the FREAK 4 hands; neither had finger transformations. Do I really have to move the fingers one by one on M4? I'm using Poser Pro 2010.
thefixer posted Fri, 23 April 2010 at 1:30 AM
Yep, there is a "grasp" dial that moves all the finger joints in one go..
Injustice will be avenged.
Cofiwch Dryweryn.
Belladzines posted Fri, 23 April 2010 at 1:41 AM
Same as there is a spread dial for his fingers too.
Trollzinho posted Fri, 23 April 2010 at 10:25 AM
How come I cant see those dials when I select the hand? Did I not install something?
jonnybode posted Fri, 23 April 2010 at 10:31 AM
Isnt that a part of the morph pack?
Trollzinho posted Fri, 23 April 2010 at 10:41 AM
I installed M4base.exe, M4Morphs.exe (Morphs++), and Michael4SkinMapsHighRes.exe. Then I installed the FREAK4 base.
Theres this M4BasePwrLoader.exe that I didn't install and I don't know whats it for...
Ghostofmacbeth posted Fri, 23 April 2010 at 10:56 AM
Did you inject the morphs after installing them?
hborre posted Fri, 23 April 2010 at 11:18 AM
M4BasePwrLoader.exe is exclusively for DAZStudio.  Has anyone mentioned updating M4 after installation to set the morph channels?
Trollzinho posted Fri, 23 April 2010 at 11:32 AM
Quote - Did you inject the morphs after installing them?
Oh what do you know... I had no idea I had to manually inject the morphs after I load Michael. That solved it ^^
Ty guys!
