Subject: No Reinitialize Python option in P8/PPro2010?
raven opened this issue on Apr 28, 2010 · 3 posts
raven posted Wed, 28 April 2010 at 7:23 AM Online Now!
I was playing around in PPro2010 with PhilC's PoserPocketKnife and ran the pz3Edit script. When it runs, a dialog box appears and states should you want to run it again after closing it, reinitialize Python. Well, in P8 and PPro2010, I can't find how. The option used to be under the 'Run Python Script' command in the File menu, it is there in P7/PPro, but not in the newer versions. To run the script again would now require a restart of PPro2010, which is a pain. Is there a reason why it was removed, or if it is still available, where?
Cheers.
PhilC posted Wed, 28 April 2010 at 8:48 AM
That's right Poser 8 and Poser Pro 2010 do not have a reinitialize Python option. My understanding is that because much of the GUI is effectively wxPython you would be fully reinitializing Poser also.
Suggest that you use the stand alone version of the pz3edit.
raven posted Wed, 28 April 2010 at 11:04 AM Online Now!
Oh, righty ho. I thought it would be to use the standalone as the workaround.
Cheers Mr C.  :)
