Subject: any one know why this is happening?
CMKook-24601 opened this issue on May 01, 2010 · 9 posts
CMKook-24601 posted Sat, 01 May 2010 at 1:47 AM
Attached Link: problem
![](http://i486.photobucket.com/albums/rr229/Xen0phage1013/WTH.jpg) I am getting this warping  especialy on wood surfaces in my last few renders I am working on in Poser 8
LaurieA posted Sat, 01 May 2010 at 1:55 AM
Can you post an image so we can see exactly what you mean? I suspect it might be a smoothing issue, but until I see what it is, I'll never know for sure...lol. Your link isn't working.
CMKook-24601 posted Sat, 01 May 2010 at 1:56 AM
Quote - Can you post an image so we can see exactly what you mean? I suspect it might be a smoothing issue, but until I see what it is, I'll never know for sure...lol.
trying and having issues ><
CMKook-24601 posted Sat, 01 May 2010 at 1:58 AM
 okay look up its there :P
basicwiz posted Sat, 01 May 2010 at 2:17 AM
 Looks like you have "Smooth polygons" turned on, and it needs to be turned off for the floor. You can do this by going to the Properties screen for the floor prop and unchecking the option there.
CMKook-24601 posted Sat, 01 May 2010 at 2:27 AM
 ahhhh lol well that makes sense and yes I had turned it one thank you :P
basicwiz posted Sat, 01 May 2010 at 2:39 AM
 I do it all the time myself!
TrekkieGrrrl posted Sat, 01 May 2010 at 3:33 AM
 It's a flaw in the prop, really. I can't for the life of me understand why any brokerage (be it Daz or this place) will accept props and scenes that does this. It's so easy to fix in the making of the thing, and it's so ANNOYING when you've spend hours waiting for a render to finish just to see that the sofa or the floor or whatever has ballooned out of place.
But yea, unchecking Smooth Polygons on the offending thing will fix it. In Poser 5 (and 6?) you had to do it on the whole scene, thereby getting poorer results from the humans in the scene (which DO benefit from the smoothing), at least in the newer versions you can do it on each separate thing.
If it's a prop/scene you use often, you could fix it permanently by changing the line(s) in the .pp2 or .cr2 from
smoothPolys 1 to  smoothPolys 0
(Easily done with a Search and Replace in wordpad or similar)
<br></br>
basicwiz posted Sat, 01 May 2010 at 9:49 AM
 Hi TG! Where ya been?
