colorcurvature opened this issue on May 03, 2010 · 7 posts
colorcurvature posted Mon, 03 May 2010 at 9:26 AM
The biggest of all mysteries:
SetMorphTargetDelta function in Posers API.
How to call it properly to have a morph target that contains absolutely nothing?
for i in range(len(actor_verts)):
param.SetMorphTargetDelta(i, 0.0, 0.0, 0.0)
This does not work. After it ran, the morph target contains what it was initialized with, e.g. the influence of JCMs.
param.SetMorphTargetDelta(i, 0.000001, 0.0000001, 0.0000001) seems to overwrite the initial values
param.SetMorphTargetDelta(i, 1.0, 1.0, 1.0)
seems to work
works only for 90% of the vertices
this some looks like either a parameter format error or bad access to memory...
Is there anyone who might know what this function is really doing or how to make it handle 0.0 value properly? I do not know how to debug Posers black heart ;-)
SmithMicro support didnt know either :(
PhilC posted Mon, 03 May 2010 at 9:53 AM
I needed this when I wrote a script that would remove all vertices associated with a designated material from a morph. However I couldn't get it to zero either. What I ended up doing was gleaning the required delta information from the original morph then using it to build a new morph.
colorcurvature posted Mon, 03 May 2010 at 10:06 AM
Most irritating is, if you setMorphTargetDelta() and then just read the value back with MorphTargetDelta(i), it tells you it would contain 0.0. If i ask it again after the script ran, it would tell me the truth and reveal it is not empty.
PhilC posted Mon, 03 May 2010 at 10:18 AM
If you would like to email me I'll send you the script.
Winterclaw posted Mon, 03 May 2010 at 11:26 AM
Question... does it have to be 0.0? Maybe the program is expecting just a 0.
WARK!
Thus Spoketh Winterclaw: a blog about a Winterclaw who speaks from time to time.
(using Poser Pro 2014 SR3, on 64 bit Win 7, poser units are inches.)
colorcurvature posted Mon, 03 May 2010 at 11:51 AM
0.0 is what i want :-).
In a desperate attempt I am now first writing 1.0 then 0.0 to everything, then afterwards set the values I computed, and in a final step I walk over everything and check if the values are what I think they are... and if they are not => exception
so rather abort than do something wrong.
but still i am not really satisfied.
wish poser was open source :)
Winterclaw posted Mon, 03 May 2010 at 5:18 PM
I was just thinking that 0.0 might be too precise for whatever program was going to accept them and that it was expecting some non-zero number since you put in the point. Since 0 = 0.0 I'd try just plain 0 at least once to see what happens.
WARK!
