Subject: How do I lock props together?
Michaelab opened this issue on May 06, 2010 · 8 posts
Michaelab posted Thu, 06 May 2010 at 7:56 AM
Hello,
I have two props that form the beginning of a sword. How do I lock the parts together (one is a cylinder for the handle and the other a flattened cone for the blade) so that when I move the modified cone the cylinder moves with it as one unit?
Thanks
Michael
Paul Francis posted Thu, 06 May 2010 at 8:00 AM
Set one to be the parent of the other.
"Object/Change Object Parent..."
My self-build system - Vista 64 on a Kingston 240GB SSD, Asus P5Q Pro MB, Quad 6600 CPU, 8 Gb Geil Black Dragon Ram, CoolerMaster HAF932 full tower chassis, EVGA Geforce GTX 750Ti Superclocked 2 Gb, Coolermaster V8 CPU aircooler, Enermax 600W Modular PSU, 240Gb SSD, 2Tb HDD storage, 28" LCD monitor, and more red LEDs than a grown man really needs.....I built it in 2008 and can't afford a new one, yet.....!
My Software - Poser Pro 2012, Photoshop, Bryce 6 and Borderlands......"Catch a  r--i---d-----e-----!"
geep posted Thu, 06 May 2010 at 8:26 AM
Export both objects (props) ... then Import the file you exported (UNcheck ALL options).
[menu] "File" >>> Export" >>> Wavefront OBJect"
Walla !!!  👍 The two props are now ONE.
cheers,
dr geep <---------------------- makin' million$ with his "glue" (Export/Import) :lol:
cheers,
dr geep ... :o]
edited 10/5/2019
hborre posted Thu, 06 May 2010 at 9:18 AM Online Now!
As the Doctor ordered.
markschum posted Thu, 06 May 2010 at 10:21 AM
Yup, those are the two ways. Its customary to parent the blade to the handle so that when the sword is used you can parent the handle to the figures hand and it all moves together.
The child moves when you move the parent. Moving the child does not affect the parent.
Michaelab posted Thu, 06 May 2010 at 10:48 PM
Thanks guys (or gals if any) that worked.
Now.... how do I go about putting specific designs on the blade and handle. I need to have the designs in very specific spots but of course, when I just apply an image in the material room it just plasters a stretched out image over the surface. How do you experts apply a Mat to a specific shape and precisely put elements of the Mat on specific areas of the shape?
Thanks.
Michael
hborre posted Thu, 06 May 2010 at 11:01 PM Online Now!
You will need to create a UVMap of your prop's mesh, laid out in a logical manner in order prepare an appropriate texture.  UVMapper is an excellent program for accomplishing this, and it comes in 2 flavors, free and Pro versions.  I do not have enough experience creating such mapping, but I do use them extensively as templates in 2D programs for texturing.
markschum posted Fri, 07 May 2010 at 12:28 AM
If you are using the poser primitives, they are already mapped. You can get the map from UVMapper as hborre says. The problem will be that as you scale the obj the uv map will stay the same, so a texture will distort.
You might do best to export and reimport the mesh and create a new map for the obj. Try just getting the current map first and see how you go with that.
http://www.uvmapper.com/downloads.html you want uvmapper classic (free)
