KageRyu opened this issue on May 08, 2010 · 6 posts
KageRyu posted Sat, 08 May 2010 at 8:41 PM
My modelling skills are not up to par for what I need, I am trying to find a decent Straight-Jacket, mental patient style garb for either M3/V3, M2/V2, or Posette/Dork. If anyone has seen one, or knows where one might be found, or could be talked into making one, I would be greatly appreciative. I need something for one of these sets, as it needs to be resource friendly.
I appreciate any help.
The New HD Toaster from Wamco toasts bread more evenly and acurately than Standard Toasters. Take advantage of the FULL resolution of your bread and try one today, because if your toast isn't in High Definition, you are not getting the most of your toast!
hborre posted Sat, 08 May 2010 at 9:22 PM
The only decent straitjacket currently available is Oskarsson's Straitjacket created for V4. Link below:
http://market.renderosity.com/mod/bcs/index.php?ViewProduct=63809&Start=31&vendor=15807
If you own Wardrobe Wizard, P8 or PoserPro 2010, you might be able to convert it.
KageRyu posted Sat, 08 May 2010 at 10:12 PM
Quote - The only decent straitjacket currently available is Oskarsson's Straitjacket created for V4. Link below:
As I said, I need one for M3/V3, M2/V2, or Posette/Dork. I do not have a way to convert things backward from the M4/V4 line, and they are not resource friendly.
JoePublic posted Sat, 08 May 2010 at 10:50 PM
Attached Link: http://www.renderosity.com/mod/bcs/index.php?ViewProduct=25046&keyword=mental
"Sanity" is for V2/V3 :hborre posted Sat, 08 May 2010 at 11:03 PM
Ah, yes. I thought I recalled another type. This one did not appear in whatever3d when I conducted the search for straitjackets.
KageRyu posted Sun, 09 May 2010 at 12:30 AM
Quote - "Sanity" is for V2/V3 :
Yes that could work - and with a few simple adjustments I can fit it to M3 as well. A little pricy for a legacy set, but I can't have everything. Just don't see how I missed this when I did a page by page search through the V2/V3 sections of the marketplace.
Thanks for the heads up.
