Arah opened this issue on May 09, 2010 · 9 posts
Arah posted Sun, 09 May 2010 at 1:22 PM
markschum posted Sun, 09 May 2010 at 2:01 PM
That looks like the mesh tearing. Check your joint zones.
DarkEdge posted Sun, 09 May 2010 at 2:01 PM
ockham posted Sun, 09 May 2010 at 2:03 PM
This often comes from a missed weld. Check your CR2 file and be sure
the 'rCollar' is welded to the 'Chest'.
There should be a pair of lines like
weld rCollar
chest
and
weld lCollar
chest
Adom posted Sun, 09 May 2010 at 2:47 PM
it is most likely what was said above but ...
it happens to me when poser runs to long (has nothing to do with cr2) - probably something gets wrong inside memory and such breaks randomly appear on the figures - restart usually helps.
Arah posted Sun, 09 May 2010 at 4:57 PM
ok Thank you everyone!
TrekkieGrrrl posted Sun, 09 May 2010 at 8:12 PM
Remember that all the collar bits must be a child of the chest bit. You can't have some of them welded to the chest and some to the abdomen for instance. That might be what's wrong here :)
The HIP is the only body part that can have more than one "child" part.
Arah posted Mon, 10 May 2010 at 1:31 PM
ok Thanks you! will try to Remember!
Arah posted Mon, 10 May 2010 at 3:52 PM
Re-starting didn't work, and i'm not exactly that learned in poser yet, to understand it all. does anyone have a tutorial that might explain how to fix it? seeing as i'm rather new at all this?
