Subject: removing morphs in v4
fatbuckel opened this issue on May 10, 2010 · 15 posts
fatbuckel posted Mon, 10 May 2010 at 12:51 PM
I would like to know how to remove multiple morphs in v4. The search on this site is horrendous at best so dont suggest a search. I tried that. I know to right-click but sometimes its greyed out (I was on the body,too)if there`s a script to remove all zeroed morphs I would like that to lighten up a few characters.
markschum posted Mon, 10 May 2010 at 1:23 PM
try freestuff poser utilities and see what scripts are there. There were a few to remove zeroed morphs .
Other than that there should be rem poses that will remove the morphs.
fatbuckel posted Mon, 10 May 2010 at 1:38 PM
I searched for "remove morphs" and got 1159 hits. Aint got time to look thru all that. BTW...why cant I copy and paste into this reply box?
hborre posted Mon, 10 May 2010 at 1:40 PM
Obviously you checked everywhere except the freesection.  Svdl has a python script to remove unused morphs.  Link below:
http://www.renderosity.com/mod/freestuff/details.php?item_id=34576
BTW, I had to reread your OP twice to understand exactly what you were after.  A little bit more information next time.  The script above should work for you.
fatbuckel posted Mon, 10 May 2010 at 1:48 PM
Quote - Obviously you checked everywhere except the freesection.  Svdl has a python script to remove unused morphs.  Link below:
Thanx a bundle!
RobynsVeil posted Mon, 10 May 2010 at 5:00 PM
I agree that Search on here is deplorable... I usually have to read all sorts of unrelated threads to get what I'm after. That's why I thought like a wiki would be useful, or something along those lines. The tutorials thing is a bit paltry next to this forum.... but you just have to find it.
Acadia has put together a stickied list (bless her heart) at the top of this forum of all the key information threads on here: I usually go there first when I'm looking for something.
But, get used to reading. Poser is not something you're going to be getting up to speed at quickly (if you're new at it) and the information you need is often-times not in the manual, or it is buried very cleverly. So, patience and time are your key allies in nutting this all out.
[it is clear that humans have contempt for that which they do not understand]
Metaphor of Chooks
markschum posted Mon, 10 May 2010 at 10:12 PM
copy and paste use ctl-c and ctl-v     (ctrl key and c etc)
nekkidchikken posted Tue, 11 May 2010 at 6:13 AM
But isn't there a morph that allows you to view morphs and remove those you don't want? I thought I had found one but can't locate it now. Looked here and over at Okham's site. The remove all zeroed morphs is a great tool, but sometimes you want to keep morphs that aren't currently being used.
hborre posted Tue, 11 May 2010 at 11:51 AM
The intention for stripping out the zero morphs is to make the character's file size lighter.  But this is only applicable for a particular scene and not for saving a reusable character.  You are correct, though, there are specific morphs better left intact which could be used later if pose changes are necessary.
chriscox posted Tue, 11 May 2010 at 4:49 PM
Attached Link: Morphography - Utilities
You can strip morphs out of a file with Morph Manager.  Itr won't show Body channels for files with a .cr2 fextension but it will show them for files with a .pz2 extension.
You can also do this with an editor for Poser files such as "CR2 Editor" or "Poser File Editor" in the markplace
Chris Cox
hborre posted Tue, 11 May 2010 at 6:25 PM
Interesting.  I wasn't aware you could do that with Morph Manager.
nekkidchikken posted Tue, 11 May 2010 at 7:55 PM
Morph Manager.
Yes, that's the one I thought I had. I'll give it a go.
wdupre posted Wed, 12 May 2010 at 2:34 AM
I haven't used morph manager for years but as I recall you could only add and delete morphs one bodypart at a time, it would be really tedious to do it for a whole figure.
Easypose Underground on the other hand will remove the master and all its slaves all at once.
nekkidchikken posted Wed, 12 May 2010 at 4:22 AM
Do you have a link for that? I searched R'osity without finding it.
nekkidchikken posted Wed, 12 May 2010 at 4:46 AM
Never mind. Found it. A bit pricey for just removing morphs, I think. I'll take the tedious route for now. Not knocking the product or price. It seems to do a LOT, just more than what I wanted it for.
