FutureFantasyDesign opened this issue on May 12, 2010 · 11 posts
FutureFantasyDesign posted Wed, 12 May 2010 at 8:48 AM
OK, I am bang wiz at doing this in PSP (*blush) but to this day I cannot figure out how to use patterns with my brushes in PS! Specifically Antje's "FUR" brushes. I have pics of Mil cats that need severe touch up on the legs and bellies. If I could do that using a patterned texture the effect would be beautiful. Using several colors to 'duplicate' fur is tedious and killing my hand... :P
Also I am not sure why but I have trouble improting patterns (*and colors) into PS. What should I be doing???
ThanX!!!
Oh a last question... what happens to all of the old PS questions /answers here? I am so disappointed that many are gone and I cannot find the archived forum posts.
Hugs
Ariana
Is there water in your future or is
it being shipped away to be resold to you?
Water, the ultimate
weapon...
www.futurefantasydesign.com
msg24_7 posted Wed, 12 May 2010 at 12:13 PM
Unfortunately, I can help with the last question only...
You can access the archive by clicking on the "archive" link just the current list of topics...
http://www.renderosity.com/mod/forumpro/showforum.php?archive=12366
You can then set a date range... like Jan 01 1995 till March 01 2010 and you'll get all past topics.
When using the forum search, it will search the archives as well...
As long as you set a sufficient time range... like newer than 5,000 days
Yesterday's the past, tomorrow's the future, but today is a gift. That's why it's called the present.
FutureFantasyDesign posted Wed, 12 May 2010 at 5:04 PM
ThanX for the info msg24_7! I will note that! ;)
As for the other question(s)... I am waiting patiently! :D
Hugs
Ariana
Water, the ultimate
weapon...
Lucie posted Wed, 12 May 2010 at 5:15 PM
As far as I know, you cannot paint using a pattern instead of a color in photoshop. But you can paint with a color on a layer and then apply a pattern to this layer, I'm not sure this would give you the result you're looking for though.
What trouble are you talking about when you say you're having trouble importing patterns and colors? How do you proceed?
FutureFantasyDesign posted Wed, 12 May 2010 at 5:32 PM
OK, you know the Millenium Cats (*big)? Well in almost every pose there is this horrible stretching on the legs, stomache and other areas. In order to correct this texture flaw you have to painstakingly add little bits of the texture to the area, sometimes resulting in over a hundred small appliques of texture to make the cats look good. It is most likely why they are used so little. I was hoping for an easier solution to this effect... see knee joint example above> It is also a problem on the stomache because the texture there was realllly stretched at the edge of the Mil Cat seams.
All help is appreciated! :)
Hugs
Ariana
Water, the ultimate
weapon...
bdtstudio posted Mon, 17 May 2010 at 11:44 AM
It is certainly possible to paint with a texture. These instructions are for CS2 but I know they work in earlier versions.
HTH,
Barb
BDT Studio
FutureFantasyDesign posted Mon, 17 May 2010 at 12:05 PM
WOW! Thank you Barb!!!!
It is so tedious to do the cut and paste method of trying to match up any patern!
I will try this right away!
Hugs
Ariana
Water, the ultimate
weapon...
Lucie posted Mon, 17 May 2010 at 1:20 PM
Oh I love you Barb! This is something I didn't know about and it will certainly come in handy one of these days!
FutureFantasyDesign posted Mon, 17 May 2010 at 7:26 PM
Used the clone brush and cleaned up this pic on the cats!
http://www.renderosity.com/mod/gallery/index.php?image_id=2059733
Hugs
Ariana
Water, the ultimate
weapon...
bdtstudio posted Mon, 17 May 2010 at 8:22 PM
Glad it worked for you and that I could be of help, being a newbie on this forum.
FutureFantasyDesign posted Tue, 18 May 2010 at 6:20 AM
Yes you may be a newb here... but obviously you know your PS! I am finding that PS is a constant present that you open and find a new gift almost every day thanx to smart folk like yourself!!! I honestly do not mind postwork, but this had become just ridiculous in scope. So your advice is safely stored in my PS folder under best Tuts!!! (*hint)
Hugs
Ariana
Water, the ultimate
weapon...
