greatlights opened this issue on May 15, 2010 · 7 posts
greatlights posted Sat, 15 May 2010 at 8:43 AM
I have downloaded Jessy-Lady Hair from www.renderosity.com/mod/freestuff/details.php free item by plus3d
The item is at RuntimeLibrariesPose! HAIR Fit Poses but doen't work.
Thank you for your help
jonnybode posted Sat, 15 May 2010 at 9:02 AM
Is this not only a hair fit pose?
Do you have the original hair?
SSAfam1 posted Sat, 15 May 2010 at 9:28 AM
Attached Link: Lady Hair
> Quote - I have downloaded Jessy-Lady Hair from [ www.renderosity.com/mod/freestuff/details.php](http://www.renderosity.com/mod/freestuff/details.php?item_id=34517) free item by [plus3d](../../../mod/freestuff/index.php?user_id=407587) > The item is at *RuntimeLibrariesPose! HAIR Fit Poses* but doen't work. > > Thank you for your helpThis is not the actual hair. It's a pose fit; meaning the actual hair needed was made for another character so had to be updated to fit others (in this case, Jessi). The original hair is required to use this. Actual hairs are usually in Hr2, Cr2, and PP2 format. Anything with Pz2 is a pose file which either moves a figure, changes a fit, or changes the texture colors of an actual figure/prop.
See attached link for the hair needed to use the freebie Jessi pose fit.
greatlights posted Sat, 15 May 2010 at 10:38 AM
I'm only a beginner so I didn't know this.
Now I understand wht y it was not working.
TrekkieGrrrl posted Sat, 15 May 2010 at 11:38 AM
Most of us has been there, done that :-) so don't feel bad. Most poses ect. in free stuff will say 'for 「character」' when it requires something to work, but it takes a little etting used to.
ice-boy posted Sat, 15 May 2010 at 12:05 PM
i think the word '' fit'' should be in the title.
jerr3d posted Sat, 15 May 2010 at 6:15 PM
Attached Link: Digital Babes
If u needs some free Hair models greatlight you might try these, although they are mostly for Vicki 3 you might could scale them to fit V4.
