mach opened this issue on May 21, 2010 · 5 posts
mach posted Fri, 21 May 2010 at 8:11 AM
Hi,
I'm getting an out of memory message when I try to render certain combinations of objects . I've encountered this issue once before on a previous computer and worked around it by increasing a parameter which I have since forgotten. Does anyone know how to correct this issue? I.m using Poser 5 with Vista os and 4GB ram.
IsaoShi posted Fri, 21 May 2010 at 2:08 PM
Does Poser 5 have a render setting for Bucket Size?
If so, what Bucket Size are you using? Have you tried reducing it? This will reduce memory usage during the render.
what I should be."
Murakami)
mach posted Fri, 21 May 2010 at 2:42 PM
I've been using the Poser 4 Render option, but I'll try experimenting with the Firefly render engine which does have a bucket size.
Thanks
TrekkieGrrrl posted Fri, 21 May 2010 at 8:53 PM
In the early Poser versions, "Out of Memory" doesn't always mean that it's ACTUALLY out of memory. It may also mean "I've encountered something i don't know what to do with. I give up" - like, for instance, a missing texture map. The later Poser versions (I think from 7 and above) has finally left that generic error message for something more actually fitting :)
mach posted Fri, 21 May 2010 at 11:33 PM
I believe that your asesment is probably correct. I increased the page file size but the Poser 4 render option still crashed. However the render works using the firefly render engine on the same scene. I prefer the P4 render option to the firefly because it looks sharper to my eye.
