serene opened this issue on May 23, 2010 · 3 posts
serene posted Sun, 23 May 2010 at 1:48 PM
Hi, guys. As usual, looking for help since I can't gain it by searching.
I've created a 347 frame walk animation with Walk Designer in Poser Pro 2010. I want particular poses at both ends of the animation, I've ticked what appears to be the right boxes for the 15-frame transitions at the beginning and the end of the animation, but when it's played back the animation just loops back to frame 1 again instead of the final frame with the pose I loaded. The figure slides across the scene during the last 15 frames back to it's start position.
What am I doing wrong?
Yours frustratedly, and HELP!
lesbentley posted Sun, 23 May 2010 at 7:02 PM
It seems to work for me in P6. I created 153 frames. Moved the slider to frame 153, and set a pose, then ran the Walk Designer set to a 153 frames walk cycle. In the last 15 frames the figure (Posette) transitioned more or less smoothly into the pose I had set in frame 153.
serene posted Mon, 24 May 2010 at 2:01 AM
Yep, done all of that. The one thing I haven't done is set a precise frame count in Walk Designer to match the initial frame count- I'll try that and see what happens. Walk Designer always sets more frames than I determine at the outset.
