Subject: Why does this happen?
Prometheus273 opened this issue on May 24, 2010 · 8 posts
Prometheus273 posted Mon, 24 May 2010 at 5:46 PM
This is the Michael 2 suit.  In Preview mode it looks fine.  But when I render it in firefly it looks semitransparent.  Not sure it shows well in the attached pic but even the sleeves are semitransparent.   I checked the materials and there is no transparency map loaded.  All materials are set to 0% transparency.  This is Poser 7 with all updates, by the way.
RobynsVeil posted Mon, 24 May 2010 at 5:56 PM
Would you be able to show us a screen-capture of the material room (advanced) please?
Also, are normals set to forward?
[it is clear that humans have contempt for that which they do not understand]
Metaphor of Chooks
Prometheus273 posted Mon, 24 May 2010 at 6:20 PM
I set normals to forward as you suggested and then rendered again.  Even the pants are semitransparent
seachnasaigh posted Mon, 24 May 2010 at 6:41 PM
The transparency edge value is set at 1;  this will cause transparency in obliquely-viewed areas.  Set it to 0.
RobynsVeil posted Mon, 24 May 2010 at 6:46 PM
What seachnasaigh said...
...this is why I like to see the shader itself.
Metaphor of Chooks
markschum posted Mon, 24 May 2010 at 7:09 PM
gee if you can read that pic I need better glasses :)
RobynsVeil posted Mon, 24 May 2010 at 7:12 PM
Um, I could barely make out that 1under transparency_edge... you do have a point, Mark.
Metaphor of Chooks
Prometheus273 posted Mon, 24 May 2010 at 7:15 PM
That was it.  Thank you very much everyone.  Only some of the bodyparts were set like that.  Don't know how they got changed.  Thanks again.
