templargfx opened this issue on May 25, 2010 · 19 posts
templargfx posted Tue, 25 May 2010 at 5:47 PM
Attached Link: http://www.oo-software.com/home/en/products/oodefrag/index.html
Hi All,I just thought I'd share my latest discovery with you all.
I have PP2010, and my runtime is well over 40Gb with around 150,000 files in there.
When I started up Poser previously, it would take a good 60+ seconds while it searched my runtime for all the stuff thats in there. It was painfully slow, and my HDD sounded like it was going to have a heart attack!
I recently found an application called O&O Defrag Professional (see Link), you can run this program on a free trial, so doing this yourself will cost you nothing!
After installing, I told the program to do a "COMPLETE - NAME" defrag on my Poser drive. What this does is manually move all of your files on the drive, so that they are physically stored on the disk in alphabetical order!!
If you dont see why thats so good, think about it this way, when Poser wants to read the contents of my runtime, the head in the drive is positioned at the start, and in one smooth sweep of the disk surface it can read the entire thing, there is no need for it to jump back and forth over the drive as it reads the contents.
This took my 60+ second runtime check all the way down to under 5 seconds!
TemplarGFX
3D Hobbyist since 1996
I use poser native units
Zaycrow posted Tue, 25 May 2010 at 7:04 PM
Sounds too good to be true. The SR3 update still takes over 3 minutes to run the scan and uses 2.3GB of ram :(
Haven't tryed your link yet but if others can confirm this I will give it a go.
madno2 posted Tue, 25 May 2010 at 11:10 PM
I use OO Defrag for many years now. Had it on win XP, win Vista and now run it under Win7 64 bit. Works fine. I let it run periodically every few month. Maybe because of that I never had the extremely slow reading of the runtimes that many here in the forum reported.
If you use the "complete name" method the first time, expect some hours of running time and a very heavy load on your hardisk.
OO Defrag installs a windows service that is active even if you don't use the software. With an older version of OO Defrag I had to set this service to "start manually" because it created some background load. The current version (v12) does not do this at least on my computer.
Together with the free ccleaner (www.piriform.com/ccleaner) that was mentioned in some threads (that tool that finds and deletes all the temp stuff that fills up the harddisk even the millions of hidden files Poser7 leaves in the Internet Explorer history folder and also fixes errors in the win registry) I was able to fix / avoid some of the problems reported here in the forum.
KimberlyC posted Wed, 26 May 2010 at 12:12 AM
Sounds interesting. I use CCleaner at least once a month to get all the junk that hides out within my computer that make the computer lack.
_____________________
.::That which does not kill us makes us stronger::.
-- Friedrich Nietzsche
vilters posted Wed, 26 May 2010 at 5:20 AM
I Run Ccleaner;
Advanced System Care free
Glary utilities,
one a day on the 5 PC Systems :-)
Poser 1, 2, 3, 4, 5, 7,
Dev
"Do not drive
fishak posted Thu, 27 May 2010 at 2:15 AM
I downloaded, and gave it a shot, but if you are taking advantage of the fact that PP2010 runs natively on 64 bit, this defrag tool isn't for you. 00Degrag won't install on 64-bit OS.
I use Auslogics Disk Defrag. It is native 64-bit, very fast, has a good options set, and is completely free.
madno2 posted Fri, 28 May 2010 at 8:46 AM
I use OO Defrag on win7 64 bit. It installed and works fine.
Never heard of Auslogics Disk Defrag. Free sounds good :-)
Byrdie posted Fri, 28 May 2010 at 12:46 PM
All my runtimes except the main Poser one are on an external drive. Will this work for a setup like that?
aeilkema posted Fri, 28 May 2010 at 3:40 PM
Get rid of the P8/2010 library and Poser will run smooth again. I've got Library XL installed and it takes just a few secs to load and check things.
Food for thought.....
inklaire posted Sat, 29 May 2010 at 8:08 PM
Quote - Get rid of the P8/2010 library and Poser will run smooth again. I've got Library XL installed and it takes just a few secs to load and check things.
Agree. I have it too.
I just couldn't work with the P8 library.
madno2 posted Mon, 31 May 2010 at 2:41 AM
To Byrdie,
yes defragmentation software also works with external harddisks. But the defragmentation takes more time than with an internal hdd, especially if the ext. hdd is an USB one. The idea to replace Posers library with another one is also a way to go (strange isn't it? One of the main features of Poser is to display a huge amount of content data to the user. But even now after a lot of rewrites of the Poser library a lot of usesrs are still so unhappy with it that they are willing to pay money for third party solutions).**
templargfx posted Mon, 31 May 2010 at 3:10 AM
the main problem with the current library is that it searches everytime you start up poser. how about making a db of everything thats there, and only updating when you choose (as you have to update if you add anything while its running anyway, which for me is like all the time)
TemplarGFX
wimvdb posted Mon, 31 May 2010 at 5:23 AM
The library only reads the open folders at startup.
There is a checkbox "reopen folders" in the library preferences. If you uncheck that P8/PP2010 and the library will start up quickly. Now if you click on folders it will read them as you open them.
bagginsbill posted Mon, 31 May 2010 at 10:02 AM
I'm almost too exhausted correcting misinformation on this forum anymore.
Most of those who replaced the P8 library with a 3rd party did so after the first iteration. They have never once demonstrated that they tried the new one and used the settings to adjust it to their choices. Among those is the setting not to re-open folders. There is little to no startup cost if you think it's OK and desirable to not re-open folders from previous sessions. Some people prefer it, some don't. It's your choice. But it would help if people actually paid attention to the features of the software before claiming to know how it fails.
madno2 posted Wed, 02 June 2010 at 2:09 AM
My example of library speed:
Startup time time of Poser (after a PC reboot - so nothing is in the cache) including opening of the library and opening the folders from the last session: 20 seconds.
Navigating through the library (opening folders, changing the runtime etc.): under 1 to a max. of 2 seconds.
Conclusion:
For me the librarys speed is absolutely ok.
I feel that: - defragmentation gives speed
Vex posted Wed, 02 June 2010 at 8:50 AM
I don't have the defrag option on macs - and i'm fairly certain it auto-defrags files. i don't have too much speed issues but i'm curious about runtime sizes. mine is just over 40gb for my 'main' ( which is an external runtime )
I only install python products to my poser folder runtime, everything else goes to a different runtime folder.
Do you guys split up runtimes because smaller runtimes are faster or for just organization purposes?
I have my only external runtime organized, separating hairs, from shoes, from aerysoul, p3d, etc. and v4 chars, and poses and what not, navigation isn't too much of an issue for me.
estherau posted Wed, 02 June 2010 at 9:26 AM
Vex - I too am on a mac and do the same thing and find scrolling down through the library very fast.
I do find changing parameters dials on a fully loaded V4 very sluggish though which is a separate issue.
Love esther
Vex posted Wed, 02 June 2010 at 9:32 AM
My material room and dialing parameters is ALWAYS slow!!! I love dazstudio because its so fluid regardless of whats loaded.
estherau posted Wed, 02 June 2010 at 9:38 AM
yes, until you save a very big file in DS. It can take hours! Loading inDS is also fairly slow.
I am really hoping the 64 bit mac version of poser with loads of ram will speed up using those dials. Unfortunately there is no news on how SM are going with that.
Love esther
