Forum: Freestuff
Subject: Corroded BioHazardBarrel
jenay opened this issue on May 30, 2010 · 5 posts
jenay posted Sun, 30 May 2010 at 5:35 AM
Attached Link: My downloads
The package contains a simple, low-poly scifi barrel with biohazard texture. There are 2 different texture versions included, a slimey green one, and a rusty red one. Developed and tested with Poser 5 (uses a shader node setup), should work with Poser 6/7/8 as well.
My downloads can be found at:
http://www.joes3dfantasyworlds.com/down/scifi01/scifi01.htm
infinity10 posted Sun, 30 May 2010 at 6:45 AM
 Thanks !  Taken.
Eternal Hobbyist
Yokasobi posted Sun, 30 May 2010 at 11:59 AM
Thanks Joe! You do great stuff.
Whazizname posted Tue, 01 June 2010 at 12:18 PM
Thank you!!
The pre-arranged barrels will be quite handy, too!!!
jenay posted Wed, 23 June 2010 at 4:20 AM
Hi All,
it came to my attention that one texture was missing in my package "biohazardbarrel02.zip".
that's a pity, because without this texture my elaborate shader set doesn't work
as intended. It's a greayscale gradient texture that is needed for the blender node.
I updated my ZIP and added the missing texture.
You can download it here:
http://www.joes3dfantasyworlds.com/down/scifi01/biohazardbarrel02.zip
Hope it works now :)
