Forum: Poser Python Scripting
Subject: Rename Node?
Vex opened this issue on Jun 10, 2010 · 3 posts
Vex posted Thu, 10 June 2010 at 10:58 PM
I have shaderspider and PP2010 but when i try to run 'rename node' from the wacro menu in mat room, it says
Traceback (most recent call last):
  File "/Applications/Poser Pro 2010/Runtime/Python/Poseworks/ShaderSpider/wacros/Rename_Node.py", line 7, in ?
    import pre as re
ImportError: No module named pre
How else can we rename nodes in the Mat Room besides saving mat then renaming thru text editor ?
nruddock posted Fri, 11 June 2010 at 5:08 PM
Quote - I have shaderspider and PP2010 but when i try to run 'rename node' from the wacro menu in mat room, it says
    import pre as re
Edit that line of the script to read as follows :-
import re
If you can't do that for some reason you can't edit the script, download an editable copy from -> http://www.poseworks.com/shaderspider/
Vex posted Fri, 11 June 2010 at 5:54 PM
 awesome thank you very much! :)
