Subject: Help converting movie from poser pro 2010 64 bit.
magnemoe opened this issue on Jun 18, 2010 · 10 posts
magnemoe posted Fri, 18 June 2010 at 6:31 AM
I made a 240 frames animation in poser, however the video formats I can export in are limited, I can export to images, flash and avi, the avi codex is either avi version 1, some intel encoding I can not read or uncompressed who work. But make large files, this
http://www.youtube.com/watch?v=XUNXJO-jXOE is 230MB.
Anybody know of free / cheap and simple programs to convert uncompressed video or series of pictures to a decent format? It had been useful to reduce the frame rate a little here to make her walk slower without increasing size.
thefunkyone_4ever posted Fri, 18 June 2010 at 7:59 AM
I would say install DivX or Xvid codecs (they can be found easily with a google search), And use www.virtualdub.org to process your raw avi into one of the compressed formats !
Thats about the best way !
LostinSpaceman posted Fri, 18 June 2010 at 11:55 AM
In order to have more options for rendering AVI's in Poser Pro 2010, you'll need to run the 32 bit version. There are very few 64 bit video Codecs available at the moment that you can use. DivX doesn't have 64 bit codec's yet. Not Sure about XVid.
magnemoe posted Fri, 18 June 2010 at 1:56 PM
Ty, I downloaded divx, xvid and virtualdub who compressed my 900MB uncompressed file down to 50MB. My problem was that I had only downloaded videolan and no codexes
Thank for the tips about 64 bit, would probably need to run poser in 64 bit  so I save as uncompressed and convert later, might think about saving to images as it should be easier to redo part of a animation.
Anyway, had to resize it to make youtube take it
http://www.youtube.com/watch?v=xlpivMK6JAU
is it a way to get youtube to loop a video, this is designed to run in a loop, the other option is to but the loop scene in many times after each other.
LostinSpaceman posted Fri, 18 June 2010 at 2:55 PM
Unfortunately, no, I don't know of any way to make YouTube loop a video. Yours looks good though and I know Windows Media Player will loop it just fine.
Tashar59 posted Fri, 18 June 2010 at 5:54 PM
Or save as sequenced image files and put them together in virtualdub and save to what ever codec you want.
flibbits posted Sat, 19 June 2010 at 1:02 AM
Don't render in any video format.  Render as sequenced images, then use virtualdub to put them together as a video file.  It supports many codecs.
If the computer crashes in the middle of a video render you have to start at the beginning.
If it crashes in the middle of an image series render, you re-start after the last completed image.
magnemoe posted Sat, 19 June 2010 at 8:55 AM
Yes this is that I will do, as you say it will make it possible to continue after crash, can also make a simple script to copy and rename the files for repetitions.
Should also be possible to redo part of an animation with a problem.
Tashar59 posted Sat, 19 June 2010 at 6:46 PM
OK so I said save instead of render. Thought that was obvious what I meant. LOL.
When I render I save as image files. LOL.
MistyLaraCarrara posted Tue, 22 June 2010 at 8:58 AM
Quote - Don't render in any video format.  Render as sequenced images, then use virtualdub to put them together as a video file.  It supports many codecs.
what if you have a lipsync audio file with the animation?
If you add the audio later, does the audio still sync with the sequenced images?
Thanks.
