renderroneous opened this issue on Jun 21, 2010 · 10 posts
renderroneous posted Mon, 21 June 2010 at 5:08 AM
R.P.Studios posted Mon, 21 June 2010 at 6:10 AM
What version of Vue are you using ?
Did you try removing the negative light ?
I'd rather be hated for who I am, than loved for who I am
not.
bruno021 posted Mon, 21 June 2010 at 6:12 AM
What lighting model? Is "reuse indirect lighting" on in your render settings?
renderroneous posted Mon, 21 June 2010 at 6:40 AM
I knew I would forget important info, lol. I'm using Vue 8.4 latest build. The lighting model is GR, with only optimize for outdoor rendering checked. I don't have the reuse indirect light box checked. I haven't tried removing the negative light, but I will.
renderroneous posted Mon, 21 June 2010 at 9:30 AM
and I removed the indirect light, and the artifacts are still there.
Jonj1611 posted Mon, 21 June 2010 at 9:43 AM
Texture issue maybe, its only happening on branches that I can see.
Change to user settings and turn of texture anti-aliasing and see if it makes a difference.
Jon
DA Portfolio - http://jonj1611.daportfolio.com/
renderroneous posted Mon, 21 June 2010 at 1:02 PM
Jon I think you may have nailed it. I did a test and it seems to have corrected the problem. Of course, the final render will show if it really helped or not. I'll post it when it's done. Thanks.
Jonj1611 posted Mon, 21 June 2010 at 1:08 PM
Good luck with it mate, there are other options to try if it wasn't a texture issue.
Regards
Jon
renderroneous posted Tue, 22 June 2010 at 7:32 AM
The texture antialiasing seems to have been the cause of the problem in this case. Thanks everyone. The finished render just got posted in the gallery.
Jonj1611 posted Tue, 22 June 2010 at 7:54 AM
