3DNeo opened this issue on Jun 22, 2010 · 3 posts
3DNeo posted Tue, 22 June 2010 at 4:19 PM
Since reporting several major bugs with Poser imports to e-on regarding the "Poser Shader Tree" issues I found and others, I am trying to get the most out of Vue without them. Having said that, I have seen some of the tips, such as those by a user here "Silverblade", but wanted to find out if anyone had some others too? Mainly, I could use some for HAIR when imported. I have tried a few things, but can't get it to look as good as in Poser Pro itself.
If anyone can post anything for tweaking the materials or render settings for optimal REALISM, that would be great. NOTE: I am after the most realistic looking character renders possible and while I know "SkinVue" helps with this some and have played with it, I am just wanting to see if I can get them to look as good as I have them in Poser Pro.
Thanks for any tips.
Jeff
Development on: Mac Pro 2008, Duel-Boot OS - Snow Leopard 10.6.6 &
Windows 7 Ultimate 64bit, 2 x 2.8 GHz Quad-Core Intel Xeon , 10GB
800 MHz DDR2 RAM, NVIDIA GeForce 8800GT.
DAM3D posted Tue, 22 June 2010 at 5:59 PM
What version of Vue are you using? It might make a difference, not sure. I use 8.5i and I have ran into similar issue with DAZ stuff, maybe this thread will help...
[ http://www.renderosity.com/mod/forumpro/showthread.php?thread_id=2804406
](http://www.renderosity.com/mod/forumpro/showthread.php?thread_id=2804406)
My
Rendo-Space
Do you know where your towel is?! I love Vogon Poetry. :P
DON'T PANIC!
Portland Pirate Festival
Arrrr!
3DNeo posted Tue, 22 June 2010 at 6:41 PM
Quote - What version of Vue are you using? It might make a difference, not sure. I use 8.5i and I have ran into similar issue with DAZ stuff, maybe this thread will help...
I'm using Vue 8.5i as well.
Note that I do know Vue as I was the one that was working with a tech over at e-on and found several issues with the Poser imports as was described in detail over at e-on. The thread you referenced has those issues on scaling due to certain bugs I found as well and they have all been documented and sent to Smith Micro by the Vue tech I was working with. When a fix is available no one knows. All they do know is my bugs have been documented and sent to Smith Micro and it is unknown when they will fix it for them to use in Vue.
That is why I am trying to get the best results possible NOT using the "Poser Shader Tree" and such. What I was asking is for more advice on tweaking HAIR in Vue along with skin materials and render settings for the best realism to look as good as they do in Poser. I have found hair to be the most difficult to get right.
Jeff
