Subject: Problem closing & saving in PP2010
ecccoman opened this issue on Jun 24, 2010 · 4 posts
ecccoman posted Thu, 24 June 2010 at 4:29 PM
I have run into a problem when I try to close a scene in PP2010.  When I close & save the scene PP2010 refuses to close!  If I persist in closing, I completely loose the scene!  My pz file has 0 KB!
I saved periodically as I was building the scene without incident.  The scene was not overly large - 6 figs, clothes and a some props.  I have 6 gig ram and a core i7 processor.
This has happened twice in a row & wasted a lot of work.
Any ideas what could be causing this?
Thanks
magnemoe posted Sat, 26 June 2010 at 2:46 AM
Can you save and then close without saving? Always use that method myself as it feels safer.
Do you run it on a 32 bit system? I had lots of problems with it running out of memory and misbehave with 32 bit.
Might also be a character object you use who causes problems.
Magic_Man posted Sat, 26 June 2010 at 6:17 AM
I get issues closing PP2010 on a Vista laptop with an ATI card - P8 was fine. Event log suggests it's an OpenGL problem with my ATI card, which is not suprising since I have other OGL issues with it. Files get saved okay though even if on the close, it's just the program doesn't close nicely.
ecccoman posted Sun, 27 June 2010 at 4:10 PM
Thanks for the input
I need to do more experimenting.  But, I believe the problem is with the size of the scene.  I was getting well over 400,000 KBs.  Need to do more experiments.
I thought the sky was the limit on an i7, 6 gig, 64b machine.  I guess not.
