232bird opened this issue on Jul 01, 2010 · 12 posts
232bird posted Thu, 01 July 2010 at 9:12 AM
I have gotten hooked on dynamic cloth since figuring out how to use it, I even converted some clothing figures to props to use in the cloth room. I have been through the tutorials on how to use it and it is pretty simple to match a clothing item that has areas smaller than the base figure (poke-through before the simulation is run). I just use morphs in frame 1 to reduce the size of the figure. But how would I get a clothing item to match a figure that is SMALLER than the clothing item to begin with? I tried scaling the x, y and z scales on the clothing item down to fit inside the figure, then used an extreme emaciated morph on the figure to fix any poke-through. The final result was that the clothing item was bent and twisted, and did not match the figure. The best I can rekon is that the item has deformed too much by the time the morph in the figure has caught up to it for it to be able to match the figure. Anybody know how to fix this?
