santolina-sailor opened this issue on Jul 06, 2010 · 3 posts
santolina-sailor posted Tue, 06 July 2010 at 12:44 PM
I could use some advice on how to get an AVI 14 gig into Nero 10 to burn as a DVD
Avi is an Aftereffects lossless AVI.to date Nero doesnt recognise the format.
P
markschum posted Tue, 06 July 2010 at 1:13 PM
www.videohelp.com check the tools tab for dvd authoring tools
you will want it as an mpeg2 format I think for normal dvd. You may need to split it to 2 dvd unless you can use a double layer disk . You may be ok with the compression anyway.
geep posted Tue, 06 July 2010 at 1:14 PM
Attached Link: http://www.avs4you.com/
You might want to check this one out.It will convert (almost) anything to (almost) anything.
I have used this to produce DVDs with no problems whatsoever.
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
