xpdev opened this issue on Jul 16, 2010 · 14 posts
xpdev posted Fri, 16 July 2010 at 4:56 AM
I saw some pictures of M4 with the veins of the body visible.
can anyone tell me where to find the kind of skin ?
thanks
Poser Pro 2014 SR 1 on Windows 7 64
bit
I use IDL, Gamma Correction and EZSkin for all
final renders.
hborre posted Fri, 16 July 2010 at 5:57 AM
Do you actually mean visible or prominent? If you are referring to 'popping out', then there is one product for sale @ DAZ3D.
http://www.daz3d.com/i/3d-models/-/m4-displacement-maps?item=8356&_m=d
However, it only works for DAZStudio..
There is a freebie script which will accomplish the same effect @ RuntimeDNA. Developed by Semidieu, and it can be found here:
MistyLaraCarrara posted Fri, 16 July 2010 at 8:49 AM
The displacement maps from DAZ link Hborre gave you are .tiff files.
I used 'em by manually attaching the .tiffs to the displacement plug.
with displacement values of .5, 1.0, etc.
xpdev posted Fri, 16 July 2010 at 9:00 AM
Wich is the "displacement plug" ?
many thanks
bit
final renders.
hborre posted Fri, 16 July 2010 at 10:35 AM
That is a plug connection on the PoserSurface node in the advanced section of the Material Room. Currently, I am not at my own computer, so I can't give you a screencap of it's location.
xpdev posted Sat, 17 July 2010 at 12:08 AM
Dear hborre, can you help me again with better information about "displacement plug" ?
Many thanks.
bit
final renders.
hborre posted Sat, 17 July 2010 at 4:52 PM
For your particular query, ignore all the other connects in the image and look down the PoserSurface to where Displacement is encircled. Look to the right of that plug and you will notice a wire connection attached to a set of nodes. In this instance, we have a grayscale Displacement Map connected to a Displacement Bias, in turn, connected to Displacement of the PoserSurface. This is not always the arrangement, displacement maps are usually darker and not connected to bias nodes, but I am just illustrating a point.
By increasing the increment values on the PoserSurface Displacement dial, you can add varying degree of mesh displacements to your texture to enhance its appearance.
hborre posted Sat, 17 July 2010 at 5:02 PM
hborre posted Sat, 17 July 2010 at 5:10 PM
hborre posted Sat, 17 July 2010 at 5:13 PM
Anthanasius posted Sat, 17 July 2010 at 5:13 PM
Forgot a little thing ... The displacement bias is a substract math fonction ...
Value1 set to 1 and plug your map
Value2 set to 0.5
xpdev posted Mon, 19 July 2010 at 1:01 AM
Many thank Anthanasius
but i'm not able to find the way to add the different node in your image....
bit
final renders.
Anthanasius posted Mon, 19 July 2010 at 11:33 AM
xpdev posted Tue, 20 July 2010 at 3:30 AM
Ok, that's work !!
Many thanks to everyone.
bit
final renders.
