uncle808us opened this issue on Jul 22, 2010 · 12 posts
uncle808us posted Thu, 22 July 2010 at 11:20 AM
I want to move up to Poser 8 from 7 on my Mac 10.5.8. Will my Python scripts from Poser 7 work in Poser 8? I have quite a few PhilC scripts.
MacBook Pro OSX El Capitan Ver 10.11.6
jonnybode posted Thu, 22 July 2010 at 11:37 AM
Hi!
I didnt get any trouble at all with my collection of scripts when i moved from Poser 7 to 8.
As i recall the move from Poser 6 to 7 wasnt so smooth
uncle808us posted Thu, 22 July 2010 at 11:48 AM
Did you just move them into Poser8?
jonnybode posted Thu, 22 July 2010 at 11:58 AM
Yes, as i recall i just copied the scripts over.
PhilC posted Thu, 22 July 2010 at 11:59 AM
Poser 8 uses the same version of Python as Poser 7 so pretty much all my Poser 7 scripts work in Poser 8. Same installation/directory structure.
Except Wardrobe Wizard because that is now embedded into Poser 8. You can however still use your Poser 7 WW2 support files in Poser 8. To aid with that I've made a utility script available that will copy the files over for you.
http://www.philc.net/store_WW_Extra_Figs.php (Scroll about half way down the page.)
Hope that helps.
uncle808us posted Thu, 22 July 2010 at 12:22 PM
Thank you guys, Phil that more than helps. Thank you. Kinda nervous about moving to Poser 8.
Lucifer_The_Dark posted Thu, 22 July 2010 at 1:27 PM
Just wait till you get playing with the new lighting, you'll forget you ever had Poser7. ;)
Windows 7 64Bit
Poser Pro 2010 SR1
uncle808us posted Thu, 22 July 2010 at 1:33 PM
Thanks
uncle808us posted Fri, 23 July 2010 at 10:39 AM
Phil: I filled out the form two times but have not received a reply. Maybe you are busy. I just wanted you to know.
PhilC posted Fri, 23 July 2010 at 12:08 PM
The email gets sent automatically the moment you click the request button. If you can not find the email in your spam filter send me an email directly and I'll attach the file to my reply.
PhilC posted Fri, 23 July 2010 at 12:16 PM
OK found your address so have emailed you a copy.
uncle808us posted Fri, 23 July 2010 at 12:18 PM
Ok Thanks.
