Inception8 opened this issue on Jul 25, 2010 ยท 2 posts
Inception8 posted Sun, 25 July 2010 at 1:56 AM
I have this navel piercing. I had made it into a conforming figure. Everything was fine when it's just good ole V4 default.
But then when you apply a character morph that changes the body shape of V4 in other words changes the placement of where the navel is now, the navel piercing stays exactly where it wants to in the default V4 navel position.
How the hell do I then make that navel piercing follow the navel to the new location as a conforming figure/object.
What do I need to include in the navel piercing figure that allows for that when you've applied a character morph.
I ended up just saying the hell with it and Prop it. Apply the morph, load the prop, DIY positioning but I'd like to figure out what I'm missing to make it work the way I'd like to work as a learning process.
If someone out there has a clue. It would be of interest to me.
Jules53757 posted Sun, 25 July 2010 at 2:51 AM
You have to add the simulated body morphs to the piercing as the morphs change the position of the navel. Don't use something like a Mag set or other morph transfer tools as those will deform also your piercing.
Ulli
