Stormi opened this issue on Apr 25, 2001 ยท 4 posts
Stormi posted Wed, 25 April 2001 at 5:00 PM
"The best and most beautiful thing in life cannot be seen, not
touched, but are felt in the heart."
Stormi posted Wed, 25 April 2001 at 5:58 PM
bloodsong posted Thu, 26 April 2001 at 10:37 AM
heyas; the stuff is uvmapped from a frontal projection. that is, you sorta project the texture at the obj from the front. which means, that on the sides, the facets are side-on to your texture, which means they smear out like this. this example you have here, isn't really that bad. if you want to remap to fix it.... well... texture weapons for deep paint supposedly does this for you (for 1200 bucks for the package). you could also try selecting the side polygons with the poser grouping tool, and telling it to 'create perspective uvs,' which will flatten out the affected area. if you want to use uvmapper, you can try going into selecting-by-vertex mode, grabbing the edges of the skin(cloth) where it is smushed together, and stretching it out. since uvmapper doesn't have a lasso tool, this is rather difficult. you could also try box-mapping, which will 'shoot' an image of the front/back as well as the sides (and top/bottom), instead of the planar-mapping which only does the front/back. whether a box map is easier to paint on.... well, there's twice as many seams that you have to match up. ::
Stormi posted Thu, 26 April 2001 at 11:00 AM
Hi Bloodsong, Thank you for the reply. Since writing this I tried the box-mapping and it comes out really nice by pouring the texture into the map rather then cutting out the map which left what appeared to be rips all over the place. Any defect that they might have you would need a microscope to find as it all matches, front, back and sides. I appreciate it that you took the time to offer help and I'll give you're suggestions a try also.
