Zak666Williams opened this issue on Aug 06, 2010 · 4 posts
Zak666Williams posted Fri, 06 August 2010 at 2:38 AM
in the terrain eaditor in vue 8.5 infinite their is no DIG option next to the Rais button WTF?
how to you dig in this thing?
jifl posted Fri, 06 August 2010 at 3:43 AM
In the terrain editor under "Apply 2D Brushing", there is an option "Invert". Select this and you can dig to your heart's content.
Jifl
Zak666Williams posted Fri, 06 August 2010 at 4:32 AM
thanks. ;)
Arraxxon posted Sat, 14 August 2010 at 12:41 PM
If you're looking for more digging / raising control, for instance, if you don't want to dig (or raise) deeper (higher) than a certain depth (height), than you can use the button "Altitude" in the '2D' brush mode area.
Next to this button there is another small symbol called 'eye dropper'.
By selecting the eye dropper, you will see a partially transparent layer appearing in your terrain.
Now if you click at a certain height in your terrain, you will set a new fixed height, at which your digging (if this layer will be below you digging) or terrain raising (if this layer will be higher than your raising surface) will be stopped, if needed ...
( Or you can directly input a value in the data field next to the eye dropper symbol, to position this invisible digging or raising limit ).
