boolprop opened this issue on Aug 09, 2010 · 5 posts
boolprop posted Mon, 09 August 2010 at 1:29 AM
HI. I'm new to making my own textures. I'd like to make some for the Morphing fantasy Dress. I am currently using GIMP but I know PSP very well and so I knwo how to create images using these. I want to create something that has a pattern on it, and somthing with folds..but of course you can't just lay a flat pattern on a template of the fantasy dress and expect it to look right. I just thought someone might have a tut out there for beginners with some tips on how to get the material to align to the body correctly when using a pattern or folds.
LBAMagic posted Mon, 09 August 2010 at 11:07 PM
I'm not very good with any painting program but recently I tried the following.
Load the dress into DS then export it as an OBJ into a temp folder.
Open up the dress OBJ into "Sculptris". It is a free 3D modeler from ZBrush.
http://www.zbrushcentral.com/showthread.php?t=090617
Sculptris will recognize that the OBJ already has a UV map and then asks you if you want to go paint it or sculpt it. Answer that you want to paint it and you are taken to it's simple paint room.
In Sculptris paint room you can do your painting on the 3D model. maybe can use it to paint simple guide lines or rough work then you can export your painted UV map from Sculptris and open it in Gimp or Photoshop to do further more detailed painting.
Note Sculptris may crash depending on how large the OBJ is and what your PC system is.
Following is link to video tutorial for painting in Sculptris.
http://www.zbrushcentral.com/showthread.php?t=91753
bnetta posted Tue, 10 August 2010 at 6:10 PM
this is the best tut for painting the mfd that i have ever seen in yrs...
http://chohole.francemi.net/texture_tutorial.htm
boolprop posted Wed, 11 August 2010 at 1:46 AM
Quote - I'm not very good with any painting program but recently I tried the following.
http://www.zbrushcentral.com/showthread.php?t=090617Sculptris will recognize that the OBJ already has a UV map and then asks you if you want to go paint it or sculpt it. Answer that you want to paint it and you are taken to it's simple paint room.
Thanks I've never heard of Sculptris. I'll give it a try.:)
Quote - this is the best tut for painting the mfd that i have ever seen in yrs...
Oh that look s really helpful!! Thanks.;)
