markok13 opened this issue on Aug 12, 2010 · 3 posts
markok13 posted Thu, 12 August 2010 at 10:02 AM
Is there a way to configure PoserPro 2010's Queue Manager so that it uses some temp directory other than C:Documents and Settings[username]Local SettingsTemp?
I'd like to try using a different disk for the temp files for queued renders, and I can't find the way (if any) to configure this in Poser or Queue Manager.
Thanks.
markok
nruddock posted Thu, 12 August 2010 at 5:33 PM
Try setting the TEMP environment variable to the directory you want to use.
markok13 posted Fri, 13 August 2010 at 12:06 PM
Quote - Try setting the TEMP environment variable to the directory you want to use.
Arrrgh. I don't know why I forgot about Windows's TEMP variable. Thank you.
Though actually, I ended up doing it a different way: I configured the disk in question to mount right on my "Local SettingsTempQueue Manager" directory rather than having a drive letter.
Having a disk dedicated to doing nothing but Queue Manager temporary files has really sped up the renders I'm doing at the moment. But I can imagine renders where it would help very little at all.
-- markok
