meltz opened this issue on Aug 18, 2010 · 14 posts
meltz posted Wed, 18 August 2010 at 9:44 AM
hborre posted Wed, 18 August 2010 at 10:09 AM Online Now!
Could you screencap your render settings?
geep posted Wed, 18 August 2010 at 10:17 AM
remove the ... gophers? :lol:
(sorry, couldn't resist)
cheers,
dr geep ... :o]
edited 10/5/2019
meltz posted Wed, 18 August 2010 at 10:25 AM
here are my render settings. The same as i always use for my figures.
meltz posted Wed, 18 August 2010 at 10:26 AM
Miss Nancy posted Wed, 18 August 2010 at 2:10 PM
I can never remember if those are due to bad AO settings on materials.
geep posted Wed, 18 August 2010 at 2:17 PM
Try checking "Remove backfacing polys" and see what happens ... :blink:
Two sided polys present ??? (they usually render black)
cheers,
dr geep ... :o]
edited 10/5/2019
aeilkema posted Wed, 18 August 2010 at 3:39 PM
Make a note of which sky you did use and then I would pick a different sky from the Terradome collection and render the image again to see what will happen. Most likely all of the black will be gone. There a one of two sky/light settings from Terradome that do cause this, I don't recall which ones. Whenever I encounter this problem with Terradome, it seems to me that the light is casting shadows from an object that isn't there, perhaps was left behind accidentely by the makers or a wrong setting used.
The other thing that could be going on is that the hills are casting shadows. For the light that casts the shadow , set the to a lower figure, like 0,8 and see that happens then.
If choosing a different sky will get rid of the problem, head over to RDNA and mention the problem. I think I've seen it brought up there before and they may have a solution for you.
Food for thought.....
Tessalynne posted Fri, 20 August 2010 at 3:57 PM
If you uncheck cast shadows in the properties for the ground objects it should eliminate the black spots.
Pengie posted Fri, 20 August 2010 at 5:55 PM
Quote - remove the ... gophers? :lol:
If he removes all the golfers, who's gonna pay the grounds fees?
geep posted Fri, 20 August 2010 at 8:17 PM
Gophers ... GOPHERS .............. not golfers ............ sheeeesh ... :lol:
You know ... 4 legged critters .... not 2 legged critters. :lol:
cheers,
dr geep ... :o]
edited 10/5/2019
YngPhoenix posted Sat, 21 August 2010 at 1:18 AM
meltz, just curious to hear if any solution was found. I've been trying to recreate it but no luck.
Silke posted Tue, 31 August 2010 at 4:44 PM
grichter posted Tue, 31 August 2010 at 5:55 PM
Quote - A golfer's gopher would be called a caddy, right? :P
Ergo... remove the caddys.
SORRY!
The original poster is going to scream...If I was you I would ask Bill Murray how to get the grass render correctly. :crying:
Gary
"Those who lose themselves in a passion lose less than those who lose their passion"
