SlayerX opened this issue on Aug 18, 2010 · 8 posts
SlayerX posted Wed, 18 August 2010 at 6:27 PM
Ok, I will be doing some projects based from the movie 2012 if anyone remembers it, also I am taking some info from the bible too.
One of the projects I will be doing is on famine, I have an idea on the terrain I got planned and will see how that goes but here's the following I need help or advise with.
Which M3/M4 model do I use to add some type of starvation look on, is there a morph for this?? I never done something like that so I need some help around this area.
Thanks.
markschum posted Wed, 18 August 2010 at 7:31 PM
the pic attached is m4 with morphs from BODY set to emaciated 2, young .5 and then some of the morphs for upper body , arms and legs set to make them thinner. A few morphs were set to negative values like chest size. All in the BODY actor.
You should be able to get similar results with m3 .
You will need the morphs for either mike. I dont know of a free starvation morph.
SlayerX posted Thu, 19 August 2010 at 12:33 AM
Mark, thanks for the info, I will have to jot this down when I get the chance since I'll be doing tests and poses for the scene, I got M4 and the morphs so I will use your advice on this one, thanks alot.
Appreciate it greatly.
Junior
markschum posted Thu, 19 August 2010 at 1:03 PM
There should be a setting to emphasis the ribs , but I didnt see it quickly. It does need some tinkering . Good luck .
SlayerX posted Mon, 23 August 2010 at 5:24 PM
Yeah no kidding it was tricky for the option to pop up, but I got it.
SamTherapy posted Mon, 23 August 2010 at 8:00 PM
Don't forget there's the free M2, with morphs built in.
SlayerX posted Wed, 25 August 2010 at 4:04 AM
Where can I get this??
raven posted Wed, 25 August 2010 at 11:32 AM
Attached Link: http://www.daz3d.com/i/3d-models/free-3d-models?cat=382&_m=d
Have a look at the link for the free figures at DAZ. Go through the various pages and you will find a Reduced Resolution V3 and M3 (which are loaded with morphs) as well as the morph loaded M2 and V2 figures, and their respective Reduced Resolution versions too. Although they are free, you still need to add them to your cart and go through the checkout to 'purchase' them for nothing.
