Forum: Vue
Subject: Vue Infinite PLE & Poser Pro 2010 (is there an update?)
StealthWorks opened this issue on Sep 14, 2010 · 7 posts
StealthWorks posted Tue, 14 September 2010 at 3:49 PM
 I recently bought Poser Pro 2010 and was interested in trying to import a figure from Poser Pro 2010 into Vue Infinite PLE edition. However, when I try to configure Poser import from the Vue preferences it only lists up to Poser 8. Are there any updates to PLE that fixes this? When I go to the updates section in Vue you have to enter serial numbers etc. but PLE doesn't have any of these!
Any help greatly appreciated
Thanks
bruno021 posted Tue, 14 September 2010 at 6:11 PM
I doubt this will be implemented with Vue9 coming along. You might have to wait fo the Vue9 PLE, should be out in 3 months if e-on keeps the 6 month release  cycle...
Peggy_Walters posted Tue, 14 September 2010 at 9:31 PM
Pretty sure if you configure Vue for Poser 8 it will work for Poser Pro 2010 too.
LVS - Where Learning is Fun!
bruno021 posted Wed, 15 September 2010 at 3:33 AM
There will be problems Peggy, because Vue will look for geometries and textures in the Poser 8 folder, I think I read something about it in this forum. Worth a search.
sirrick posted Wed, 15 September 2010 at 4:08 PM
I'm not sure about Vue PLE, but in Vue 7 Infinite one of the options is "Poser Pro".  I'm using PP2010 without a problem.
StealthWorks posted Thu, 16 September 2010 at 4:25 PM
 Thanks for all your responses. Its a shame it doesn't support it but, I have a copy of Poser 7 so maybe I'll reinstall that.
Thanks everyone
Michael314 posted Sat, 02 October 2010 at 4:21 AM
Hello,
I just ran across the same problem. I just selected "Poser 8", but gave the path of PoserPro 2010 (64 bit). A couple of quick tests with some static scenes worked.
I used the 64 bit current (8.5) PLE version.
Best regards,
   Michael
