uncle808us opened this issue on Sep 27, 2010 · 14 posts
uncle808us posted Mon, 27 September 2010 at 1:14 PM
In the Preview in Poser 7 Mac my object shows correctly but when I render it is totally black. Never had this happen before. Any ideas????
MacBook Pro OSX El Capitan Ver 10.11.6
lesbentley posted Mon, 27 September 2010 at 1:17 PM
With the object selected, could you post a screen shot of the material room advanced tab? It might give us a clue.
Also, check that the normals are forwards.
colorcurvature posted Mon, 27 September 2010 at 1:29 PM
is it the first/only thing that you loaded into the scene?
uncle808us posted Mon, 27 September 2010 at 1:36 PM
Here you go.
uncle808us posted Mon, 27 September 2010 at 1:37 PM
Quote - is it the first/only thing that you loaded into the scene?
Yes only thing in the scene. Also It works right in Poser 8.
uncle808us posted Mon, 27 September 2010 at 1:49 PM
If I put a primitive like a sphere then the milk carton renders correctly. What is up?
uncle808us posted Mon, 27 September 2010 at 2:06 PM
Same as in Poser 8 if I have another obj it renders OK but remove the object or figure and render is once again black.
Miss Nancy posted Mon, 27 September 2010 at 2:25 PM
it's a known bug. small objects exhibit self-shadowing by a square shadow map.
incr. obj. size to figure size and it renders properly. or add second obj to increase scene size.
in addition, uncheck "refl. lite mult" - bad poser 4 setting.
uncle808us posted Mon, 27 September 2010 at 2:29 PM
Will do....
uncle808us posted Mon, 27 September 2010 at 2:52 PM
Did that and it fixed the problem. But it screws my proportions.
SamTherapy posted Mon, 27 September 2010 at 4:11 PM
Put another object in the scene, such as the one sided square. Keep it out of the camera view and your prop should render ok.
uncle808us posted Mon, 27 September 2010 at 4:15 PM
Yes that works.
SamTherapy posted Mon, 27 September 2010 at 5:03 PM
There's your solution. Not elegant but at least it works.
uncle808us posted Mon, 27 September 2010 at 5:41 PM
Thanks everyone
