Schecterman opened this issue on Oct 14, 2010 · 4 posts
Schecterman posted Thu, 14 October 2010 at 11:57 AM
I'm just wondering if there's a way to reset all morphs and all bends on all body parts to 0 in a figure?
If not a way to do it with Poser itself, a script, maybe?
Thanks. :-)
SamTherapy posted Thu, 14 October 2010 at 12:05 PM
Edit - Restore, AFAICR.
You can also reset morphs by right clicking on the Parameter dial window and selecting "Restore".
Failing those, A REM pose to delete morphs and a Zero pose to get rid of any bends. There's a Zero pose built in to Wardrobe Wizard.
PhilC posted Thu, 14 October 2010 at 12:24 PM
Edit > Restore > Figure will reset it to its default state. This is not always a fully zero state.
Many figures come with a "zero pose" pose. If yours does not you may want to spend a moment manually zeroing everything then saving such a pose. Ensure that the option to save morph data is included.
Wardrobe Wizard does indeed include a zero pose button but I think you'll find that it will also zero out the magnets which you may not want. That being the case you may want to use it to create your zero pose then when saving to the pose library just omit the magnet data when you click the "save subset" button.
The Poser Pocket Knife has a selection of zero posing tools ranging from zeroing everything to just zeroing the morphs.
Hope that helps :)
Schecterman posted Thu, 14 October 2010 at 12:33 PM
I appreciate it.
Yeah, I know all about Edit>Restore, but I have a few figures that are already "memorized" fully morphed out and I want to zero them all. Pretty big task because in addition to all the ++ morphs, I've made several hundred of my own.
Hmmm, I'll have to take a look at that Poser Pocket Knife when I get some time. Looks like I could use alot of that, so thanks!
