westcat opened this issue on Oct 14, 2010 · 7 posts
westcat posted Thu, 14 October 2010 at 9:54 PM
JimTS posted Thu, 14 October 2010 at 10:35 PM
the clothroom uses obj props not cr2's
A word is not the same with one writer as with another. One tears it from his guts. The other pulls it out of his overcoat pocket
Charles Péguy
Heat and animosity, contest and conflict, may sharpen the wits, although they rarely do;they never strengthen the understanding, clear the perspicacity, guide the judgment, or improve the heart
Walter Savage Landor
So is that TTFN or TANSTAAFL?
westcat posted Thu, 14 October 2010 at 10:45 PM
Quote - the clothroom uses obj props not cr2's
So it will work then? How would I go about wrapping an object, like Pappy's net around the V4 and M4 then?
ockham posted Fri, 15 October 2010 at 6:02 AM
The cloth room works nicely with raw OBJ files. I use it that way all the time.
You may not be able to wrap the net entirely around a human, but you could get
it partway around.
Place the human horizontal, with the net horizontal over the human but not touching.
Scale the net up or down and move it around until you can tell that it will
drape over the right parts of the human.
(This is the hard part, and will probably take several complete tries to get it right.)
Set the timeline for 30 frames or more.
Select the net; get into the cloth room; Clothify the net.
In the "collide against" dialog, pick the parts of the human that need to be
surrounded by the net.
Start the simulation.
When done, get out of the cloth room and find the frame that looks best.
With the net still selected, hit Object : Spawn Morph Target, and give the
morph a name.
Save the net as a Prop. It will then have a morph that pulls it into the
position you made with the cloth room.
westcat posted Fri, 15 October 2010 at 6:35 AM
thanks that's great !
bopperthijs posted Sat, 16 October 2010 at 11:17 AM
*the clothroom uses obj props not cr2's
*That's not completely correct, you can use a body part of a CR2 as a dynamic object. It's called a "hybrid" CR2. I've made two chair's who use this technic: a beachchair and a folding chair. You can download them from my freebies and follow the instructions to see how it works.
Best regards,
Bopper.
-How can you improve things when you don't make mistakes?
westcat posted Sat, 16 October 2010 at 11:14 PM
Fantastic thankyou ALL !
