Subject: Savig Pose File
Cybertenko opened this issue on Oct 17, 2010 · 5 posts
Cybertenko posted Sun, 17 October 2010 at 3:45 PM
Hallo, I ve encountered some problem with saving pose file - I have figure turned back to default position and I need her to turn so it faces the default position with the face. But with reloding the saved pose it still is back to me...
nruddock posted Sun, 17 October 2010 at 4:53 PM
I suspect you didn't (or couldn't for older versions) include the body rotations in the saved pose.
Cybertenko posted Sun, 17 October 2010 at 5:13 PM
yes, probably, how to include it?
imax24 posted Sun, 17 October 2010 at 7:23 PM
When saving a body pose to the library, you are given the option of including Morph Channels or Body Transformations. The second one will include any movement or rotation of the entire body. Otherwise the figure will be posed in the zero position, facing in whatever direction you have set the hips to face.
The Morph Channels option is for when you want to inject a saved set of morph dial settings (such as Amazon or Tummy Out or Breast Size) into a figure. Normally when saving a pose to position any V4 figure, you wouldn't include these because it will reshape the figure.
Cybertenko posted Mon, 18 October 2010 at 5:04 PM
OK, I was a little dumb yesterday. I saved poses in external library which does not have additional option for saving body transformation... Bad day I gues... but thanks anyway:
