Subject: Content Collections in Poser 8
ElZagna opened this issue on Nov 03, 2010 · 11 posts
ElZagna posted Wed, 03 November 2010 at 7:59 AM
The "Poser Tutorial Manual" talks about "content collections" as a way of organizing content, but there is no such feature to be found on my version of Poser 8. The "Poser Reference Manual" alludes briefly to these mysterious collections, but doesn't really say anything about them.
I have to wonder if this was an idea that never got implemented, or is it just buried somewhere under the UI?
I'd really like to have such a feature because, let's face it, Poser's content management is a bit of a mess.
OS: Windows 10 64-bit, Poser: 10
geep posted Wed, 03 November 2010 at 9:35 AM
In Poser 8 it is called "Favorites." 😄
Add figures, props, etc. to your "Favorite" folder.
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
cspear posted Wed, 03 November 2010 at 9:36 AM
Well, the manual is a bit of a mess and would benefit from a complete re-write IMO. In this instance it seems to use 'content collection' to refer both to the stuff in your libraries and the 'favourites' feature that you can find described on Page 118 of the manual.
Note that the favourites feature doesn't organise your content, as such, it creates shortcuts to the actual library items. But it means that you can create 'collections' of stuff in ways that make sense to you.
PoserPro 11 - Units: Metres
Adobe CC 2017
ElZagna posted Thu, 04 November 2010 at 9:21 PM
Well, OK. Now that I've explored the Favorites tab a bit, I have to say that my original hunch was right -  the whole "content collections" thing was an idea that never got fully implemented. Or tested for that matter.
I would advise everyone to stay far away from it, and here's why. If you add an item to a favorites collection, a shortcut to the item is created in the ...RuntimeLibrariesCollections folder along with a corresponding .png file, all of which is fine so far. But if you then delete an item from your favorites collection, not only does the shortcut get deleted, but so does the original item itself.
If that wasn't bad enough you end up getting all these odd "Failed to retrieve file times..." errors. Plus Poser loses track of the .png file, so all you get is the "clueless man" icon or whatever it's called.
That indicates to me that the "favorites" functionality really wasn't ready when Poser 8 was released. Perhaps they've fixed it in a subsequent release, but the version I have has serious problems with favorites.
Dizzi posted Fri, 05 November 2010 at 6:51 AM
Quote - not only does the shortcut get deleted, but so does the original item itself.
Well, that should have been fixed with the first Service Release.
bagginsbill posted Fri, 05 November 2010 at 4:30 PM
Whoa. I know that bug was reported because I reported it. It was fixed, confirmed fixed, and cleared from the bug list.
Somebody must have accidentally undone the fix.
Report it to SM.
geep posted Fri, 05 November 2010 at 6:17 PM
ref: Poser 8  (8.0.3.11793)
BB,
Just tested ... 😄
FYI - Deleting a prop from "Favorites" DOES NOT delete the prop from the Props Library.
cheers
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
ElZagna posted Fri, 05 November 2010 at 6:57 PM
Maybe I have an earlier version. Looks like mine is 8.0.0.10157.
bagginsbill posted Fri, 05 November 2010 at 7:37 PM
Yes. You should upgrade. There were several hundred bugfixes since 10157. Plus the library GUI has many additional features. After you upgrade, click the "Klingon Toothpick" at the bottom of the library window and have a look at all the stuff you can set.
Thanks, dr geep. I just assumed we were all talking about the current version and I can't test it myself because I no longer keep Poser 8 on my computer.
geep posted Fri, 05 November 2010 at 8:42 PM
cheers,
dr geep ... :o]
edited 10/5/2019
WandW posted Fri, 05 November 2010 at 8:55 PM
Quote - Thanks, dr geep. I just assumed we were all talking about the current version and I can't test it myself because I no longer keep Poser 8 on my computer.
Had to make room for Poser 9 alpha, eh? (wink-wink, nudge-nudge, say no more!)
