elianeck opened this issue on Nov 09, 2010 · 7 posts
elianeck posted Tue, 09 November 2010 at 5:07 AM
Hi..
I use Carrara 8 now and if I open one my scene its to slowly...my scenes usually have 900 until 1 gb...how can I get more memory for the carrara work better?
I have 2 GB memory in my computer
tks a lot
huggs
Elianeck
Sueposer posted Tue, 09 November 2010 at 9:04 AM
If you use windows 7 there is a function called "readyboost". If you plug in a flash drive and right click on it, you can select readyboost. It turns the flash drive into a high speed cache, very quick for read-write activity.
PhilW posted Tue, 09 November 2010 at 10:55 AM
Hi Eliane, Given that the system requires some memory to work, 2GB is really prety low these days. I'd consider adding some more RAM if you can. Depending on your computer this can often be done quite cheaply and you will notice the difference!
elianeck posted Tue, 09 November 2010 at 12:22 PM
ok!
tks Sueposer, tks PhilW..!!!!!!!!!
**hugs
pauljs75 posted Tue, 09 November 2010 at 4:01 PM
Heck, even when I upgraded after my last motherboard died - even I got 4GB. Might have went for more, but I decided to stick with my OS disk that I paid for already.
If you're sticking with 32-bit XP, 4GB is about all you need (or can) to push it to. But if upgraded to a 64-bit OS, you can go crazy with it (at least what's reasonable within your budget.)
More memory is always good. It lets you do nifty things like screen-capture video recording without too much lag.
Analog-X64 posted Tue, 09 November 2010 at 6:27 PM
The readyboost is an interesting Idea I never thought about trying to use it.
I agree with everyone else here. 2GB is the Minimum for Windows 7.
4GB would be a good start.
elianeck posted Wed, 10 November 2010 at 9:00 AM
I use windows XP
tks
