fleshoff opened this issue on Nov 24, 2010 · 5 posts
fleshoff posted Wed, 24 November 2010 at 4:36 PM
when i apply a material such as a rock material to an object and animate the object across my screen, the material moves across the object instead of staying in one place on the object. What am I doing wrong?
It's like Rorschach's mask in the Watchmen if you know what I mean.
fleshoff posted Wed, 24 November 2010 at 5:19 PM
FrankT posted Wed, 24 November 2010 at 5:32 PM
object parametric instead of world parametric by any chance ? :)
fleshoff posted Wed, 24 November 2010 at 5:44 PM
yeah but I'm using a mixed material and set both to object and also the mix, but I still have animation going on in the blend area.
EDIT:figured it out...I had more than two materials...ugh.
One other question, when a frame finishes rendering on the last step before a new frame it becomes blurry and renders that way in Broadcast setting but not final. I've turned off any motion blurring etc but still can't get a sharp image, any ideas?
bruno021 posted Wed, 24 November 2010 at 6:12 PM
That's normal I think. When using Broadcast and up, Vue switches automatically to the soft AA strategy. This is to avoid flickering, and should be left as is. Other AA strategies (sharp and crisp) will introduce flicker in your materials.
