KageRyu opened this issue on Dec 03, 2010 · 6 posts
KageRyu posted Fri, 03 December 2010 at 3:42 PM
Ok, I have made dozens of Smart Props in Poser 4 Pro without any hitches. I am familiar with the process and the tutorials (which all seem to date back to P4). For the first time though, I have tried applying the process in Poser 7 Pro and had dissapointing results. After the objects been imported, scaled, re-exported, positioned, and parented - when I save it to the library I neither get the prompt to save it as a smart prop, nor does it save as a smart prop. Instead it goes straight from the select subset to the saving, and saves unparented, with wierd scaling and rotational values. I have double checked my parenting, positioning, and re-done the process step by step, and it keeps doing this. I figure this must be something with Poser 7 Pro, is there a step I am need to add, something I am missing not in the tutorials? Has anyone else encountered these issues?
I would greatly appreciate any help.
For technical reference, I am using a Wavefront object, and attempting to parent to Daz3D's Troll's hand.
The New HD Toaster from Wamco toasts bread more evenly and acurately than Standard Toasters. Take advantage of the FULL resolution of your bread and try one today, because if your toast isn't in High Definition, you are not getting the most of your toast!
