Forum: Poser Technical
Subject: My Poser 7 Parameters Window Won't Show all the Dials
romangirl opened this issue on Dec 07, 2010 · 11 posts
romangirl posted Tue, 07 December 2010 at 11:16 AM
This problem drives me crazy.   I'll be trying to create a character from, say, Michael 4. When I click on head or body to make changes, I can rarely get to the bottom of the Parameters window.  The attached figure shows how far down I can go in the window. Minimizing some of the higher parameters in the window sometimes helps, but very rarely.
EnglishBob posted Tue, 07 December 2010 at 11:32 AM
You should have a scroll bar down the side of a long palette. I'm not sure why you don't, but it may be that one of Poser's GUI definition files has become corrupted, which would probably mean re-installation; but wait a bit in case someone else has another idea. Your mouse wheel should also scroll the dials; does that work?
markschum posted Tue, 07 December 2010 at 12:58 PM
I have had this occasionally , but its hard to reproduce. Look at the bottom right corner of the bar in EnglishBobs picture, you see thats a resize button (for lack of a better word) . If you pull that sideways you widen the bar. That may get you the slider. The slider only appears when the content is longer than the bar.
romangirl posted Tue, 07 December 2010 at 2:46 PM
I usually do have the slider bar on the right.   But when I try to drag it down, it only goes so far, then stops.  Thanks!
romangirl posted Tue, 07 December 2010 at 3:31 PM
But you are right.  Sometimes I don't have the slide bar.
romangirl posted Tue, 07 December 2010 at 3:34 PM
I can't get low enough to find the resize button.  And yes, I can move the dials that are visible.
markschum posted Tue, 07 December 2010 at 5:57 PM
I would find C:Documents and SettingsOwnerApplication DataPoser 7poser ui prefs_1024_768.xml and rename it.
Poser should recreate it .
Note : owner might be something else its what you sign on as.
1024 x 768 is your screen resolution, yours may be different.
romangirl posted Tue, 07 December 2010 at 7:19 PM
documents and settingsOwnerPoser 7libraryprefs.xml is the closest I get to what you listed.   No screen resolution is indicated.
EnglishBob posted Wed, 08 December 2010 at 3:53 AM
My UI prefs are in C:Documents and SettingsUserApplication DataPoser 7English on one machine, and C:Documents and SettingsUserApplication DataPoser 7 on another - I have no idea why...
markschum posted Wed, 08 December 2010 at 9:52 AM
Which folder it goes in depends on if you installed Poser for current user only or ALL users of the PC.  Dont delete libraryprefs.xml , it would be recreated but you would have to respecify all your external runtimes.
romangirl posted Wed, 08 December 2010 at 9:57 AM
OK thanks!
