tgg373 opened this issue on Apr 26, 2001 ยท 3 posts
tgg373 posted Thu, 26 April 2001 at 11:01 PM
I was wondering if I need 3D Studio Max for working these props? Is there a way to get them to work in Poser, maybe? Thanks ahead of time.....
wyrwulf posted Thu, 26 April 2001 at 11:06 PM
import
Wizzard posted Thu, 26 April 2001 at 11:11 PM
under Fileimport3ds browse to where the 3ds file is.... ijmport into poser.... set the scale at 100% figure scale to start with.... some 3ds files are very huge unscaled and will show up only as a vague shadow... some are scaled so small.. that you can barely see them.. setting the initial import to 100% will make the prop the same size as the default figure... you can rescale from there.. then save it into your prop directory. after any parenting etc... Cheers
