Subject: Getting started with Poser8
Casette opened this issue on Dec 28, 2010 · 23 posts
Casette posted Tue, 28 December 2010 at 2:47 AM
Hi Folks
I purchased Poser8 but due lots of messy things I couldn't have time to install it until now. Can someone tell me threads for an easy tut in order to use the new P8 features? Over all about realistic lightning
Thanxxx  :)
CASETTE
pjz99 posted Tue, 28 December 2010 at 2:56 AM
Read this:
http://en.wikipedia.org/wiki/Global_illumination
Poser's Indirect Lighting is basically Global Illumination.  It's a pretty major thing all by itself, although there is other stuff that's important also.  Good place to start.
My Freebies
Casette posted Tue, 28 December 2010 at 3:09 AM
Thanks Paul  :)
EDITED
But Poser8 tuts?
CASETTE
pjz99 posted Tue, 28 December 2010 at 4:40 AM
There's a lot of threads that go back and forth, I don't think there's any one good concise tutorial.  Some key settings and techniques (at least for me):
There's other stuff but imo those are the big key things.  Attached is my default scene that I start every Poser 8 scene from, which relies on the render room prop I mentioned earlier.  Right click the attachment -> Save -> rename and remove the '.txt' extension, it's a zip file.  Have fun :)
My Freebies
saibabameuk posted Tue, 28 December 2010 at 4:59 AM
You can waist anawful lot of your time and energy with Poser unless you get some good tuition.
This is the best I have found , you have to pay for it but it is good.
I started with Poser6 and left it for 3years becouse I could not work the D**********thing
What a waist ! If I had this I would have been avery happy Poser user.
Infinite Skills Instructions
SYSTEM REQUIREMENTS
Macintosh: Mac OS X 10.2+
DVD-ROM Drive
1024x768 or greater Monitor Resolution
Windows: 7/Vista/XP/2000
DVD-ROM Drive
TECHNICAL SUPPORT visit:http://www.infiniteskills.com
email:support@infiniteskills.com
phone: 858-866-9147
If you require help using your training please visit our help section where you can view instructional movies on how to get the most from you training:http://www.infiniteskills.com/help
pjz99 posted Tue, 28 December 2010 at 5:00 AM
Oops, a pretty important thing to note:  Transparency takes gobs and gobs of time to calculate with Indirect Lighting enabled.  This isn't really unique to Poser, it happens in other apps that render with Global Illumination too.  A crappy workaround is to just make stuff like hair invisible to raytracing.  It's not ideal because this stops hair from casting shadows, but it's better than waiting a week for your render to finish.  The more complex the geometry of a semi-transparent model, the worse this is; some very simple hair models may be tolerable to render without this workaround, e.g. Kozaburo's.
My Freebies
Casette posted Tue, 28 December 2010 at 5:03 AM
Quote - You can waist anawful lot of your time and energy with Poser unless you get some good tuition....
SPAM???
CASETTE
pjz99 posted Tue, 28 December 2010 at 5:07 AM
Quote - This is the best I have found , you have to pay for it but it is good.
While I'm sure that's a great overall instruction set, I looked at the full listing of topics and there is no section on using Indirect Lighting/GI, which is ... pretty crucial.
My Freebies
pjz99 posted Tue, 28 December 2010 at 5:08 AM
Quote - SPAM???
Naw I think he was trying to be helpful, but I don't think that training set is really what you're asking for here.
My Freebies
LaurieA posted Tue, 28 December 2010 at 5:20 AM
There is a small learning curve, but you'll have it down in no time ;o). Like Paul said, the biggest thing to get used to is the lighting. You sort of have to relearn it...lol. Most Poser users before Poser 8 were fairly used to faking GI, but since the IDL, you have to unlearn those habits.
Casette posted Tue, 28 December 2010 at 5:24 AM
Great tut, Paul. I'll use it. Thanks!  :)
CASETTE
pjz99 posted Tue, 28 December 2010 at 5:37 AM
As far as setting up the actual lights, start very simple - you'll notice that that blank scene I attached earlier only has two point lights for rendering.  There is one infinite light for convenience, called "WORK LIGHT - TURN OFF TO RENDER".  If you are accustomed to using IBL, try going without it until you get some idea of how Indirect Lighting behaves.  I used to use IBL as an omnidirectional fill light but that isn't required any more with Indirect Lighting (as Laurie said).
My Freebies
saibabameuk posted Tue, 28 December 2010 at 5:58 AM
> Quote - > Quote - You can waist anawful lot of your time and energy with Poser unless you get some good tuition.... > > SPAM???
hborre posted Tue, 28 December 2010 at 8:58 AM
Unfortunately, Gamma Correction is a feature exclusively found in the Pro series.  For any other version, this will need to be introduced into your materials, a long and drawn out process which I wouldn't recommend unless you are willing to convert many items to new shaders.  Bantha did create a script for the Wacro to automate this process.  Light based AO is inactivated by IDL, however I do know that material based AO, present in PP2010, can be considered under IDL rendering.  I don't know if the same feature exists under installation of SR3 for P8.
Definitely, install all the service packs available; there have been some major fixes which will make the workflow easier.
ErickL88 posted Tue, 28 December 2010 at 9:27 AM
Quote - There's a lot of threads that go back and forth, I don't think there's any one good concise tutorial.  Some key settings and techniques (at least for me):
That's really a great list, Paul, thnaks.
makes some notices himself
If you don't mind, could a have a few more words on my bolted selection of your quote, why you suggest it and why using it this way, please?
I never really seem to have understood these parameters (even tho they probalby are so easy to explain .. LOL )
Thanks.
pjz99 posted Tue, 28 December 2010 at 1:58 PM
Shadow blur radius - this is in degrees (I think) and the larger it is, the more the shadow will blur as it is farther from what is casting the shadow.  Real shadows are not sharp the way a setting of 0 will give you, except under conditions not found in nature (light is absolutely uniform, no air, other things).  Spend some time looking at real shadows from various sources and you'll see what I mean.  I like a setting of 5.0 "just because", it's not for any scientific reason.
Shadow Samples controls how smoothly the shadow is filled in - as this number is higher, the shadow is drawn more smoothly, but takes somewhat longer to calculate.  I think the default is 15, and it leaves you with shadows that look a bit grainy or dirty. Setting it to 30 is pretty good in most situations, 60 pretty much always looks good.
Shadow Min Bias is better explained in this thread - it had a lot of fun observation about how the first release of Poser 8 behaved, some of it is now obsolete so take it with a grain of salt.  The talk about how shadow min bias behaves is still accurate.  Many other things have changed since we wrote that thread though, keep that in mind.
My Freebies
Miss Nancy posted Tue, 28 December 2010 at 5:17 PM
in poser 8, as substitute for render GC, use exposure control: HSV exponential tone mapping 1.67 with gain 1.33, as in att img (d3d render firefly script; incl. in P8).  max settings shown for IDL - may cause slow renders.  usual method to learn how to do renders and shaders in poser 8 and later: search this forum, desired topic, user bagginsbill et al.  takes approx 18 months to learn how to do this.
clsiu1984 posted Tue, 28 December 2010 at 8:24 PM
Hi there,
I need a help about poser 8...how can i drag rendorosity to poser 8 picture to there.
Please email me chialsiu@yahoo.com..and i also do have winzip...how can i do that when i open poser 8 file.
FightingWolf posted Tue, 28 December 2010 at 9:01 PM
Quote - Hi Folks
Thanxxx  :)
If you are completely new to Poser then you can check out my site. I have a few free-ebooks focused on the bare basics required to get started, tutorial links, free workshops each month and some other things coming in January.  Not sure if something like that would be of use to you but, that's what I got at PoserByDesign.com
So far I haven't gotten any complaints yet. (fingers crossed)
pjz99 posted Tue, 28 December 2010 at 9:19 PM
Quote - **Casette
My Freebies
ErickL88 posted Wed, 29 December 2010 at 3:41 AM
Thanks for the explanation and the additional link, Paul.
Much appreciated :)
Casette posted Fri, 28 January 2011 at 2:29 PM
Quote - If you are completely new to Poser then you can check out my site...
Yes, I'm a completely new in Poser... 8. Not in Poser4, ProPack, 5, 6 and 7. As pjz99 quoted, completely new since september 2002. Oh, and official product betatester at Animotions and Renderotica. A complete newbie :lol:
CASETTE
Netrunner posted Tue, 08 February 2011 at 6:23 AM
Thanks alot pjz99!
I am absolutely new to the new IDL system (just know that from Cinema4D) and after I did what u wrote my render look WAAAYY BETTER!!!
