Subject: P8 .obj import/export
Einzelganger opened this issue on Jan 01, 2011 · 11 posts
Einzelganger posted Sat, 01 January 2011 at 2:37 PM
Greets all and happy new year :D,
I am trying to create a morph using an external program, trouble is poser wont export anything it just creates .obj and .mtl files with 0kb size and if i import an .obj file, poser crashes.
P8 is fully patched and up to date, what gives?
 Einzy.
RobynsVeil posted Sat, 01 January 2011 at 3:03 PM
Which OS are you using? Where is Poser installed? Might have write issues...
[it is clear that humans have contempt for that which they do not understand]
Metaphor of Chooks
pjz99 posted Sat, 01 January 2011 at 3:08 PM
What steps are you taking to export exactly?  I just exported a partial (chest, neck, collars) and full (all body parts) of a figure and both seem to be OK (Windows).
edit: importing those back in they appear OK also
My Freebies
Einzelganger posted Sat, 01 January 2011 at 3:10 PM
Lo RobynsVeil,
installed on win7 64, P8 not installed on C: also runs with admin permission
Einzelganger posted Sat, 01 January 2011 at 3:13 PM
hey pjz99,
 Your reply appeard while i was typing previous reply :D
i have  tried figure/part in and out also just tried primative sphere with default settings and get same result .obj/.mtl 0kb
pjz99 posted Sat, 01 January 2011 at 3:17 PM
If it's blowing up on just exporting a sphere prop then I'd expect you have found a bug of some kind, I'd go ahead and open a ticket with SM tech support even though they won't get back to you at least until after the weekend.  If you really can't wait for their response you might try reinstalling Poser - it can't be that you're doing something wrong, an application should never crash like that.
http://support.smithmicro.com/cs/smkb.cfg/php.exe/enduser/std_alp.php click "Start a New Incident"
My Freebies
Einzelganger posted Sat, 01 January 2011 at 3:21 PM
exporting doesnt upset poser (as afar as i can tell) its importing that detonates it :D
heres the error report, means nothing to me but hey :P
Problem signature:
  Problem Event Name:    APPCRASH
  Application Name:    Poser.exe
  Application Version:    8.0.3.11793
  Application Timestamp:    4bf2ec06
  Fault Module Name:    Poser.exe
  Fault Module Version:    8.0.3.11793
  Fault Module Timestamp:    4bf2ec06
  Exception Code:    c0000005
  Exception Offset:    006d8d69
  OS Version:    6.1.7600.2.0.0.768.3
  Locale ID:    2057
  Additional Information 1:    be81
  Additional Information 2:    be818cfb98812f760991c19bcd611f72
  Additional Information 3:    1c63
  Additional Information 4:    1c63c9d5d2d47acd8358863b90c36d66
will try re-install.
pjz99 posted Sat, 01 January 2011 at 3:25 PM
Yeah that's the same Poser build number I use (11793), I'm sure it's not that you're doing something wrong or that you missed a patch.
My Freebies
Einzelganger posted Sat, 01 January 2011 at 3:28 PM
re-installing now.........
that worked thanks, dont know why i didnt think of that :P standard Pc software procedure re-install/drivers etc
 thanks all.
pjz99 posted Sat, 01 January 2011 at 3:39 PM
Really, I wonder what was borked up in your install.  Very well :)
My Freebies
Apple_UK posted Sat, 01 January 2011 at 10:25 PM
Quote - installed on win7 64, P8 not installed on C: also runs with admin permission
  Programs installed contrary to defeault options do seem to have more problems
