Subject: Poser pre-render appearance verses Daz
cmramlow opened this issue on Jan 03, 2011 · 3 posts
cmramlow posted Mon, 03 January 2011 at 1:42 PM
Hello all -
Maybe I'm not doing it right, but I'm using both poser 2010 and daz and the pre-render scene is much better looking graphic clairity and color wise then Poser. I must not have a setting figured out or something.
I'll give you and example of what I'm referring to. If I load a model in both programs and apply body and clothe mats, get them all setup, ready to render, the veiw port dollies appear to be much less rude in color and appearance in daz then poser. I was hoping to see if poser can look as good pre-render as Daz. Is there a way?
Thank you,
Chris
wimvdb posted Mon, 03 January 2011 at 2:23 PM
Go to Render!Render Settings!Preview
Increase the texture Display Size and turn on "enable Hardware Shading", "Actual" for Transparency Display and enable "Enhance multilayer transparency"
This will improve the preview display in Poser
cmramlow posted Mon, 03 January 2011 at 3:13 PM
Thank you, that helps tremendously~
