Forum: Blender
Subject: Is there a way to add textures to a model in Blender and be shown in preview
jartz opened this issue on Jan 05, 2011 · 8 posts
jartz posted Wed, 05 January 2011 at 1:59 PM
In any version of Blender v 2.45 to 2.5x.  I'm having a heck of a time trying to put my texture map on for example V4 head so I can sculpt.  Is there a way where I can put in textures in Blender and see it on screen.
Any advice would be appreciated.
Thanks.
JB
____________________________________________________________________________________________________________________________
Asus N50-600 - Intel Core i5-8400 CPU @ 2.80GHz · Windows 10 Home/11 upgrade 64-bit · 16GB DDR4 RAM · 1TB SSD and 1TB HDD; Graphics: NVIDIA Geforce GTX 1060 - 6GB GDDR5 VRAM; Software: Poser Pro 11x
Gog posted Thu, 06 January 2011 at 2:39 AM
switch draw type to textured, then dependent on how your machine is configured you should see the textures.
Touchwood posted Fri, 07 January 2011 at 4:06 PM
In 2.5x, you can also tick the Textured solid box in the propertiies panel.
jartz posted Fri, 07 January 2011 at 5:13 PM
That must be the new version, because I don't have that in the properties panel.  Also, it seems to be a chore to get the textures to align in V4's head for example.  I have to figure out where to place them, should I check in the Planar, or the UV -- geez I don't k now what I'm doing.
Bummed!
JB
P.S., thanks for the help.
Touchwood posted Fri, 07 January 2011 at 5:40 PM
Put your cursor over the 3D view and press N to bring up the object properties panel. Expand the Display panel and the option appears near the bottom.
jartz posted Fri, 07 January 2011 at 6:24 PM
Thanks Touchwood for that, I got it.  I should know to press N to bring the object properties.
Now, am I doing this right, I want to apply the texture, but do I pick UV in the Coordinates or what other method should I use?
nruddock posted Fri, 07 January 2011 at 8:49 PM
Quote - ... do I pick UV in the Coordinates or what other method should I use?
The figure is UV mapped so you'll want to use UV coordinates (nothing else will work).
jartz posted Fri, 07 January 2011 at 10:49 PM
I did that.  I still have a lot to do.  I'll try to play around with both 2.4/2.5 within the weekend.
Thank you all.
JB
