flibbits opened this issue on Jan 09, 2011 · 15 posts
flibbits posted Sun, 09 January 2011 at 1:20 AM
Found this tutorial for creating a transparency mask (it's for V3 but tried it with H3) so the eyebrows can be changed into different colors.
http://www.daz3d.com/i/tutorial/tutorial?id=2159&_m=d
Followed it step by step, the settings look the same, but the eyebrows don't appear in the preview or render. One issue is that H3 does not have an eyebrow body part, nor does V4 (in PPro 2010). But it does seem to be visible because if transparency map is removed or the trans dial set to 0, the eyebrows are a solid color.
Can anyone help with the tutorial? Will it work with H3? Or is there a better way to change eyebrow color for H3?
