ladyperiwinkle opened this issue on Jan 19, 2011 · 9 posts
ladyperiwinkle posted Wed, 19 January 2011 at 1:37 PM
It sure would be nice to have oriental material that loads directly into Poser of different colors,sizes and shapes. (Not to good at importing jpegs into the material room with the sizeing I want).
Thank you!
scanmead posted Wed, 19 January 2011 at 2:07 PM
I'll second this request! Silks of any pattern, brocades, satin...
infinity10 posted Thu, 20 January 2011 at 2:43 AM Online Now!
http://ShareCG.com/v/31147/view/Texture/Lo-res-Tileable-Chinese-Fabric-Textures
Would my freebie low resolution tileable Chinese fabric textures be suitable for you ?
Eternal Hobbyist
ladyperiwinkle posted Thu, 20 January 2011 at 10:38 AM
I like a couple of them, but like I said I am not to good at importing jpegs into the material room with the sizeing I want -- that is why I want them already made to be in the material already. Thank you.
BionicRooster posted Thu, 20 January 2011 at 3:21 PM Forum Moderator
Attached Link: Material Room Tutorial
One of the main things to learn in Poser is the material room. I suggest taking an hour or so to explore and see what is where, etc. Attached is a tutorial explaining what to do in there. I hope it helps. And once you learn what you are doing, then you'll be able to make your own texture alterations.
Poser 10
Octane Render
Wings 3D
ladyperiwinkle posted Thu, 20 January 2011 at 8:07 PM
I can do that part its when i go into the advanced part and try to scale the pattern, that I have problems with
BionicRooster posted Thu, 20 January 2011 at 10:00 PM Forum Moderator
The problem with making a tiled material in Poser is, you may need to tile it more or less depending on the item you are applying it to. So you'll end up having to adjust those manually on a per model basis pretty much anyways. It took me a little while to wrap my head around the Advanced Material room, and I'm still learning new things all the time. One good way is to examine other peoples' shaders / texture setups and see what they did to accomplish whatever look the MAT has.
Poser 10
Octane Render
Wings 3D
MistyLaraCarrara posted Thu, 17 February 2011 at 10:40 AM
i setup material files (Poser 7) for most of this set: as tiling jpgs
http://www.daz3d.com/i/3d-models/-/jewels-of-architecture?item=5514 (Orientalia)
i could put them up in the free section, if anyone is interested.
They are material files only, you would need the Orientalia.
this set, too.
http://www.daz3d.com/i/3d-models/-/jewels-of-architecture?item=5443
HandspanStudios posted Tue, 15 March 2011 at 8:47 PM
I have a fabric materials collection at Daz, it works in Poser 6 and up that has silks and some brocades and many more in various colors and the colors are easily changed in the material room. I do plan to make more like this soon and will likely place the next one here.** **
http://www.daz3d.com/i/shop/itemdetails/?item=8925
"Your work is to keep cranking the flywheel that turns the gears
that spin the belt in the engine of belief that keeps you and your
desk in midair."
Annie Dillard
