Subject: can Poser(7) do fractal art?
MistyLaraCarrara opened this issue on Jan 28, 2011 · 18 posts
MistyLaraCarrara posted Fri, 28 January 2011 at 8:27 AM
There's some pretty cool fractal imagery in the gallery.
Can the math nodes be used to make fractal art?
where to start?
LaurieA posted Fri, 28 January 2011 at 8:48 AM
Programs that make nothing but fractals actually work fairly good for that.
MistyLaraCarrara posted Fri, 28 January 2011 at 10:49 AM
the only fractal thingamajig i have is Corel photopaint.
oh yeah, i should check with the node cult.
LaurieA posted Fri, 28 January 2011 at 11:07 AM
Xenodream makes 3D fractals. Might wanna check it out and play with it a little bit.
MagnusGreel posted Fri, 28 January 2011 at 11:07 AM
erm
what...? corel photopaint does fractals?
ok. we need to start over I think.... the stuff in the gallery's were made with dedicated Fractal programs. a list can be found here - http://www.dmoz.org/Science/Math/Chaos_and_Fractals/Software/ - not with programs like Photopaint (tho I think your thinking when it was called "fractal design" which was the name of the company, not it's function) or Poser which is a 3D posing and rendering app.
in theory, you could get Poser to render fractals, but you'd need Bagginsbill, 40 odd pots of coffee and about six months...... the same way in theory you could chop a fully grown oak tree down with a small handsaw.  this is a case of "right tool for the right job" and poser is not the right tool.
Airport security is a burden we must all shoulder. Do your part, and please grope yourself in advance.
MistyLaraCarrara posted Fri, 28 January 2011 at 11:46 AM
Lots of Hazelnut coffee on hand.  more snow is headed my way, some goof off time coming.
pjz99 posted Fri, 28 January 2011 at 11:58 AM
As the others are saying, I have no doubt you could do many, many fractal type things with Poser's material system, but unless you're a pretty good math head you're basically going to be asking someone like Bagginsbill "how do I do this one" for any that you want to do, with little room for experimentation on your own.  There are tons of apps that let you play with fractals in a huge variety of ways that will let you do a lot of "sandbox" stuff without requiring a math degree.
Apophysis is another very cool one, pretty popular.  Of the various fractal gallery pics here, probably 90% are either Xenodream or Apophysis.
My Freebies
MistyLaraCarrara posted Fri, 28 January 2011 at 12:44 PM
i saw the directory with the .xml for the nodes.  input and output parameters.
pjz99 posted Fri, 28 January 2011 at 2:59 PM
Groboto is another nifty app, although not specifically a fractal generator it's worth a look.
My Freebies
crocodilian posted Sun, 30 January 2011 at 11:29 AM
Sure, the Firefly Engine can do abstract stuff using the fractal nodes; the caveat is that they're relative slow, and they're not recursive (meaning you can't plug the output of a node back into the input). Its not designed for speed or efficiency in fractal evaluation the way that applications that are only about fractals are, but that's part of the fun of it.
The place to start is with very simple hi resolution geometry (the high resolution sphere primitive is ideal), and plugging noise functions into the displacement map. That can give you some very complex 3D geometry out of very simple scenes.
MistyLaraCarrara posted Tue, 01 February 2011 at 8:07 AM
this one kinda came out nifty.  (would Naysay Guy like this? 😄 )
MistyLaraCarrara posted Tue, 01 February 2011 at 8:09 AM
not sure how you'd tile it though.
stewer posted Tue, 01 February 2011 at 8:19 AM
You could also write Python scripts that create fractal geometry. There is already a "fractal terrain" example that comes with Python that could serve as a starting point.
MistyLaraCarrara posted Tue, 01 February 2011 at 8:43 AM
is there a python editor that is dedicated to poser python? that would be cool.
something like the VBA editor.  when you type the dot it gives you a list of the properties, etc?
bagginsbill posted Tue, 01 February 2011 at 9:20 AM
Python editor with intellisense is already in Poser 8 and Pro 2010.
crocodilian posted Tue, 01 February 2011 at 9:21 PM
My two cents worth-- create your fractal geometry with the displacement engine. The above image is simply the hi-res sphere, with a fractal texture and displacement.
Firefly has a very strong micropoly displacement engine, which means you can create very complex geometry out of a very simple primitive, and a procedural texture plugged into the displacement. In the image, note that the displaced geometry actually casts real shadows . . . so there are real polys being created on the fly at render time
Is better than trying to cook up custom fractal geometry, as that's very poly heavy, and not at all interactive (if you do fee like it, Groboto is a lot of fun, as already mentioned)
The other thing that's great about using a procedural texture to generate geometry at render time is that its dynamic-- you can always bump up the precison of the render to "get more geometry" without having to go model it.
You can also animate the texture, and get deforming geometry with a lot less hassle than trying to set up morphs.
MistyLaraCarrara posted Fri, 04 February 2011 at 8:44 AM
it almost looks like a dandelion puff
crocodilian posted Fri, 04 February 2011 at 3:25 PM
Quote - it almost looks like a dandelion puff
Ah, almost, but those would require a lot more work in Poser. The problem is that you can't "branch" at the end of a displacement, the way the puffs do.
To do [i]that[/i] would require Python, you'd have to offset little star shapes from the surface of the sphere; it could be done with Python, but much easier in something that supports growth and branching, like Bryce or Vue's Trees.
As a Poser Python exercise, it would be a great exam question, actually . . .
